How Do You Input Trig Functions into a Graphing Calculator?
To input the trigonometric function cos(2t) into a graphing calculator, use the format y = cos(2t). To solve the equation cos(2t) = 0.5, find the inverse cosine, which gives one solution, but multiple angles exist within the range of 0 to 2π. The primary angle is π/6, with additional solutions at 5π/6, 7π/6, and 11π/6. For better formatting of the pi symbol in forum posts, using LaTeX expressions like \frac{\pi}{6} is recommended. Understanding these concepts will aid in effectively using a graphing calculator for trigonometric functions.
312213
How do I input trig functions in the calculator?
An example would be cos(2t) = 0.5.
I don't understand how to start it.
How do I input this in? I am not sure how to input it into a graphing calculator. The equation to input it into y = ? would be greatly appreciated.
What you want to do is solve the equation. So for that you need, some program which solves the equation, and which most probably the calculator doesn't have. If you simply want to graph the function then input: y=cos(2t) .
The 0.5 is what I am trying to find. I forgot that's what it means. So the 0.5 would actually be at what t would I get 0.5.
Thanks for clearing that up for me.
If cos(2t)=0.5 then 2t=arccos(0.5). arccos (or cos^(-1)) is the inverse cosine function. Is it on your calculator? Once you have that, you know that that's not the only solution. Draw a graph of cos. There are many solutions, the arccos will only give you one. In this case though, you don't even need the calculator. There is a simple triangle you can draw with an angle in it that has a cos of 1/2.
The first angle would be 30°, or \pi/6.
If say I am to find the radians that equal 0.5 for functions 0 \leq t \leq 2\pi, then the first one is \pi/6. The rest of them are found by subtracting \pi - \pi/6 = 5\pi/6, adding \pi + \pi/6 = 7\pi/6, and subtracting 2\pi - \pi/6 = 11\pi/6.
This means that there and four answers and they are \pi/6, 5\pi/6, 7\pi/6, and 11\pi/6.
Is this correct?
Edit: Something small and not important but is there a way to have the pi sign not look like exponents using the forum's posting ability options and not resorting to copy/pasting character map's pi? Which still looks pretty bad. π
Just a brief note. If your calculator can find intersections between curves you could graph the two functions y = cos(2t) and y = 0.5 and find any intersections.
Is this correct?
Yes, I think. Try \frac{\pi}{6}. Click on the symbol to see how it works.
Is this correct?
Yep, looks right to me dude
Put entire expressions, not just individual symbols, in LaTex.
\frac{\pi}{6}
or
\pi/6
Instead of \pi/6
