How to interpret complex solutions to simple harmonic oscillator?
4 replies · 3K views · last reply
psie
Consider the equation of motion for a simple harmonic oscillator:
##m\ddot {x}(t)=-kx(t).##​
The solutions are
##x(t)=Ae^{i\omega t}+Be^{-i\omega t},##​
where ##\omega=\sqrt{\frac{k}{m}}##, and constants ##A## and ##B##. Physically, what does it mean for a solution to be complex? Is it only the real part that is of interest or also the imaginary part? Of course, using Euler's formula, the solution can be rewritten as
##(A+B)\cos{(\omega t)}+i(A-B)\sin{(\omega t)},##​
and one can introduce new, complex constants. However, there is still the issue of a real and imaginary part with that representation.
Both the real and imaginary parts are solutions to the differential equation by construction. If you put in real initial values, your determined constants ##A## and ##B## will result in a real solution (i.e., their sum will be real and their difference imaginary - in other words ##B = A^*##).
You can form linear combinations of your basis solutions to get real values solutions in terms of sine and cosine. That can form your new basis if you wish.
Edit: and your constants A and B can be complex in order to make this happen.
Of course at some point your solution to a physical problem must be matched to boundary conditions in space and time. That will constrain the actual result .
Another way to think about it is to say that you only look for solutions with ##x(t) \in \mathbb{R}##. That constrains the "allowed values" for the complex coefficients of you solution to ##B=A^*##. You get still the complete solutions for the real differential equation, because the complex coefficient ##A=A_r + \mathrm{i} A_i## consists of the two real numbers ##A_r## and ##A_i##, which can be used to satisfy the real (!) initial conditions ##x(0)=x_0 \in \mathbb{R} ##, ##\dot{x}(0)=v_0 \in \mathbb{R}##.
