How to know 'the displacement of a particle is 'negative'?
Displacement is calculated as delta x = x2 - x1, where x1 and x2 are the initial and final position vectors of a particle. A negative displacement occurs when x1 is greater than x2, indicating movement in the opposite direction of the chosen positive axis. For example, if a particle moves from position 5 to position 3, the displacement is negative. Practical examples include a car moving left on a number line or withdrawing money from a bank account, both representing negative displacement. Understanding the signs of x1 and x2 is crucial for determining the direction of displacement.
Medicalboy
If x1 and x2 are the initial and the final position vectors of particle respectively. Then, displacement of the particle is delta x = x2 - x1
But my question is how to know that the displacement is negtivive and its direaction? (could you provide a practical example so that I can understand easily?)
2. The attempt at a solution
Only I know that if x2 is greater than x1, the the delta x is positive
If x1 is greater than x2, delta x is negative
if x1 = x2, then delta x is zero
x2 must be less than x1
Example 1: x1 = -3, x2 = -5. Δx = x2 - x1 = -5 - (-3) = -5 + 3 = -2.
Example 2: x1 = 5, x2 = 3. Δx = 3 - 5 = -2
+1
You do that sum carefully taking into account the signs of x1and x2.
If the answer is negative then the displacement is negative.
Likes Medicalboy
CWatters said:
+1
Could you provide a phenomenon example where we can see the negative displacement?
What is positive and what is negative depends on your choice of axes. If you use the standard convention, "to the right is positive and to the left is negative", then a car moving to the left has negative displacement over any time interval during this motion.
Likes Medicalboy
Kuruman has provided two examples.
Sent from my Hudl 2 using Physics Forums mobile app
It's not conceptually much different from monetary transactions. If you take money out of your account that's a "negative displacement" of your bank balance!
  • · Replies 19 ·
  • · Replies 17 ·
