How to know 'the displacement of a particle is 'negative'?
The discussion revolves around understanding the concept of displacement in physics, specifically when it is considered negative. Participants explore the mathematical definition of displacement as the difference between final and initial position vectors, and seek clarification on how to interpret negative values in practical scenarios.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the conditions under which displacement is negative, citing examples with numerical values. Questions arise regarding the interpretation of negative displacement in real-world contexts, and requests for practical examples are made.
Several participants have provided examples to illustrate negative displacement, and there is an ongoing inquiry into practical phenomena that can demonstrate this concept. The discussion reflects a mix of mathematical reasoning and conceptual exploration, with no explicit consensus yet reached.
Participants note that the interpretation of positive and negative displacement may depend on the chosen coordinate system, suggesting that context is essential in understanding the directionality of displacement.
Medicalboy
If x1 and x2 are the initial and the final position vectors of particle respectively. Then, displacement of the particle is delta x = x2 - x1
But my question is how to know that the displacement is negtivive and its direaction? (could you provide a practical example so that I can understand easily?)
2. The attempt at a solution
Only I know that if x2 is greater than x1, the the delta x is positive
If x1 is greater than x2, delta x is negative
if x1 = x2, then delta x is zero
x2 must be less than x1
Example 1: x1 = -3, x2 = -5. Δx = x2 - x1 = -5 - (-3) = -5 + 3 = -2.
Example 2: x1 = 5, x2 = 3. Δx = 3 - 5 = -2
+1
You do that sum carefully taking into account the signs of x1and x2.
If the answer is negative then the displacement is negative.
CWatters said:
+1
Could you provide a phenomenon example where we can see the negative displacement?
What is positive and what is negative depends on your choice of axes. If you use the standard convention, "to the right is positive and to the left is negative", then a car moving to the left has negative displacement over any time interval during this motion.
Kuruman has provided two examples.
Sent from my Hudl 2 using Physics Forums mobile app
It's not conceptually much different from monetary transactions. If you take money out of your account that's a "negative displacement" of your bank balance!
  • · Replies 19 ·
  • · Replies 17 ·
