How to make KERS (Kintetic Energy Recovery System) for 2-wheeler?
  • Thread starter Thread starter tdev
    Energy System
This discussion focuses on the development of a Kinetic Energy Recovery System (KERS) for two-wheelers, emphasizing the importance of understanding regenerative braking principles. Participants highlight the feasibility of implementing KERS on both electric and mechanical bicycles, with considerations for weight, speed limits, and energy storage density. The conversation also touches on the engineering challenges of using flywheels, particularly regarding balance and control during operation. Overall, the consensus suggests that while KERS can enhance energy efficiency, practical limitations may hinder its effectiveness in typical cycling scenarios.
  • Understanding of regenerative braking systems
  • Familiarity with flywheel energy storage technology
  • Knowledge of weight and speed regulations for two-wheelers
  • Basic principles of mechanical engineering related to balance and control
  • Research the principles of regenerative braking in electric vehicles
  • Explore flywheel design and materials, focusing on carbon-fiber applications
  • Investigate state regulations regarding weight and speed limits for two-wheelers
  • Learn about mechanical balance systems for rotating components in vehicles
Engineers, hobbyists, and inventors interested in sustainable transportation solutions, specifically those looking to enhance the efficiency of two-wheelers through innovative energy recovery systems.
tdev
I want to make kers for my two wheeler.How should i start and what are the things that i should consider??
Is it an electric two wheeler?
Ahh, KERS (capitalized abbreviation) for Kintetic Energy Recovery System.
Consider its required capacity and power (time rate). 100 kg from 50 kph to zero at 1/3 g for a bicycle HPV.
how does that matter?
What you have to start with matters...
Read about regenerative braking and I think you'll understand.
timthereaper said:
Not true. The link shows that you can do this with a regular bike and a bit of ingenuity.
http://www.gizmag.com/flywheel-bicycle-regenerative-braking/19532/
That's a great proof of concept, but for a 15 pound flywheel at any significant rpm, the support is just not good (Imho) :cool: I say this only to raise awareness for anyone that might just jump up and throw something together :nb):)
I totally agree. It's shows good thinking and it's all mechanical, but I don't quite see the allure of carrying around 15 extra pounds on a bike just to save you maybe 10 percent of the energy you expend. This link is a sexier version of the electric bike conversion kit: https://www.superpedestrian.com/. I think this might be closer to something people might invest in (but I'm not a cyclist).
I have always liked the Hub Motor for electric, but the idea of flywheel energy storage for take off assist, is high on my list of ideas.
Biggest challenge is, most states have weight and speed limits, which cuts deeply into energy storage density.
Does the OP want a purely mechanical system? If the two wheeler is electric, a simple regen system might be easier.
We still don't know if Op is starting with a gas motorcycle, pedal bike or electric bike. It matters.
@tdev -- I see you are on the forum today. How about dropping into this thread and letting us know what you are wanting to do... :-)
Speed limits on how fast the flywheel can turn? I was about to suggest a carbon-fiber flywheel. It's light enough to be worthwhile but you can get that thing to spin up really fast. If there's limits to flywheel speed, then that's out.
No!, the speed and weight generally apply to electric power and a limit of around 700 watts at the motor.
A properly enclosed flywheel should not draw much restriction other than, if speeds of the flywheel cause control problems related to resistance to lean or turning.
Oh Jeeze! I didn't think of that. A spinning flywheel on a bicycle (road or MTB) could be a very bad thing. Maybe if it could gimbal it wouldn't be a problem. But that would make getting energy into and out of the flywheel much more difficult...
It might be that a second flywheel spinning in the opposite direction would solve most of the problems, however that begins to increase the engineering design efforts of dual input and power take-off applications.
Ah, good idea! :-)
Yeah the engineering would have to be more significant, but you'd have to do some sort of "balanced system" like that to make it work.
Looking at road construction concrete saw blades, you can find a blade 28" diameter and about 1/8" thick with a weight of about 15 pounds.
Mount one on each side of the frame and there will be little to indicate there are two flywheels, they are rated around 2500 RPM (while making cuts in concrete) the energy storage for a bicycle should be pretty generous. Just a quick thought :)
New they price from $800.00 to as much as $1500.00, on some occasions a concrete contractor will give them away and not bother having them reconditioned.
I'm not adding no 30 pounds to my bike! :w
"Ten per cent?" This is for some sort of "Hare & Hounds" cross-country, steeplechase obstacle course? Two seconds on the throttle, two seconds on the brakes until you're seasick?
We don't know. It is a secret.
Don't quite get what you mean. I haven't done any real number crunching, so 10% was a number I picked out of thin air. I can't imagine a system like this saving more than that amount of energy. Maybe I'm wrong though...it's been known to happen :-)
Back of the envelope bookkeeping on recovery systems just for ordinary driving, I couldn't begin to get 5% for "soccer moms" doing "stop and go" all over town, let alone pay for hauling the additional mass necessary for the recovery around.
Totally agree.
  • · Replies 41 ·
  • · Replies 21 ·
18K
  • · Replies 51 ·
