How to make water splash less?
  • Context: Undergrad
  • Thread starter Thread starter dotancohen
    Water
14 replies · 17K views
dotancohen
Is there a term for the height that a liquid splashes above it's surface when a body falls into it?
There is a certain system in our house that is designed to drop viscoplastics at quasistatic speeds into a water vessel from a height of about 20 cm. Under normal operating conditions the water in the vessel does not splash onto the receptacle dropping the viscoplastics. However, this week the receptacle is ejecting a water-based substance at high speed, which causes the water in the vessel to splash up higher than normal. This is rather uncomfortable. Are there any common household products which one could add to water to reduce the height of the splash? I tried salt but there is no effective way of mixing it and it settles too quickly.
Thanks.
put baffles in the tank.
Thanks, Cragar. The tank is actually a toilet, and that would be hard to clean! I did find that draping two layers of toilet paper over the water does help, though.
Good solution, you put disposable baffles in the tank :biggrin:
The original post here would make a great entry in a "Guess what is being described here" contest. :smile:
But seriously, hope you're better soon dotancohen.
Excellent description! I hope you feel well soon too.
That's pretty much the reverse path of how I got to posting: I tried to reduce the problem to something academic-sounding in the hopes that bells would start ringing. But I'm not a chemical engineer.
But it sounds like time for a contest! I'd love to see what others here come up with.
Finally starting too, thanks.
LOL!
How about increasing the viscosity of receptive fluid.
Maybe Jello . . . .(BTW, the splash phenomenon described in the OP is known as 'Neptune's Kiss')
tasp77 said:
LOL!
Maybe Jello . . . .
That's a great idea, seeing how unsuccessful I've been in increasing the viscosity of the effluvium. I'll see if I have some gelatin, though I don't know how well it will work without cooling.
I suppose that is a better moniker than "Uranus' endearment".
A friend of mine has suggested trying some olive oil, which would float on the surface.
That's a good idea, thanks.
For the interested, talcum powder works as well by increasing the surface tension. Protip: powder it in when you leave so that it will be ready for when you return. You won't have the patience to powder properly when you need it.
An alternative solution would be to lower the falling bodies slowly by a rope.:confused:
As you described the problem is not the operation of the receptacle, it's the input that needs to be altered. May I suggest some sort of additive.
Something similar to this.
Additive technical Specification
I think you missed the point of his post. Reread the original post with more... unsanitary thoughts
Thanks, Chris. Due to problems with the output buffering, the input stream was running on minimum bandwidth.
Things are returning to normal now, though. I think posting about it helped. Oh no, I've become this:
http://www.penny-arcade.com/comic/2008/4/23/
