PeterDonis said:
This is not something you can just assume. You have to describe what "synchronized" means and how it will be accomplished. (For example, Google "Einstein clock synchronization".)
Yes. On a practical note, one can define clock synchronization is to choose some coordinates. With defined coordinates, clocks can be defined as synchronized if they have the same time coordinate. But in general, the results will depend on one's choice of coordinates.
Clock synchronization is presented as a human choice, and to a large extent it is. However, if one wants decent compatibility with Newtonian phsyics, so one can use most Newtonian formulae, one needs to use something like Fermi normal coordinates and make sure that the region one is analyzing is "small enough". I've seen a lot of posters who deal with the clock synchnoziation issue by ignoring them :(, this almost always leads to confusion in the end.
Conventional wisdom is more along the lines of "don't use coordinate dependent methods at all". This is OK, if one can get the necessary physical intuition that way, but if one is seeking some intuitive insight, using the coordinate methods and the right set of coordinates can be helpful. Contrawise, using the wrong set of coordinates can lead to more confusion.
The biggest problem with using Fermi normal coordinates in this context is converting the GW solution to these coordinates - while the GW has a nice closed form solution in the TT coordinates, attempts to convert them to Fermi Normal coordinates quicly results in a real mess. I do recall vaguely seeing some paper on the topic that talked about this issue and (I believe) they managed to deal with the mess, somehow. BUt I don't know how.
The approach of "Fermi coordinates are too hard so I'll just use TT coordinates and interpret them in a Newtonian manner is just wrong :(.
