How to observe interference patterns with a simple experiment?
The discussion centers on observing interference patterns through simple experiments, primarily utilizing the double-slit experiment as a foundational method. Participants recommend using a visible laser, razor blades, and a dark room to create interference patterns on a wall. The setup involves taping two razor blades with a tiny gap of approximately 1/10th of a millimeter, allowing the laser light to pass through and produce vertical light and dark areas. Additional methods mentioned include using a single blade edge and reflecting a laser off a slightly dirty mirror to observe ring-shaped patterns.
  • Understanding of the double-slit experiment
  • Familiarity with laser pointers and their safety
  • Basic knowledge of light diffraction concepts
  • Ability to work safely with sharp objects in low-light conditions
  • Research the mathematical principles behind the double-slit experiment
  • Learn about single-slit diffraction patterns and their calculations
  • Explore safety measures when conducting experiments with lasers
  • Investigate other optical experiments that demonstrate wave-particle duality
Students, educators, and hobbyists interested in physics experiments, particularly those exploring wave interference and light behavior.
onqun
Hello guys, I need desperate help. I am googling an simple experiment that can observe interference patterns ? can someone help me out please?
The double-slit experiment is the best known...and is the basic building block of interference experiments.
Hello, is it possible to observe that with a diffusion ?
I did this for fun in the fall. You need a visible laser, a couple of box cutter type razor blades and a dark room at least 10 feet long. (please please please be careful. I'm talking about razor blades in a dark room. The laser is less dangerous than the razor.)
Tape the two edges of the blades together so the sharp edges face each other with a very tiny gap, maybe 1/10th of a millimeter.
You shine the laser through the gap and you will get an interference pattern (vertical light and dark) areas on the wall. The smaller the gap in the blades, the wider the spacing in the pattern. You can also use a single blade edge but the patterns are harder to see.
Don't look into the beam and don't walk around in the dark holding the razor blades.
Here's a very easy method:
http://groups.google.com/group/alt.sci.physics/msg/a53fbd5a66f9ba15
Below is some pictures I have of doing it with a padlock. The shackles on the padlock work nicely if you want to do precise measurements because they come pre-aligned. But you can get it to work even with Coke cans.
The classic double-slit experiment is also easy. You can also see some impressive ring-shaped interference patterns by reflecting a laser pointer off a slightly dirty mirror.
The key component in these experiments is the laser pointer. (That and a dark room. Don't expect to be able to see much with the lights on.) Go out and buy one; they're cheap.
One easy one you can do without a laser pointer is single slit diffraction. Just make a thin gap between two fingers and look at a distant street light through them. The disadvantage there is that you might not understand what's going on unless you know how to calculate a single-slit diffraction pattern, which is a bit more complicated than the double-slit case.
  • · Replies 28 ·
  • · Replies 60 ·
  • · Replies 23 ·
  • · Replies 65 ·
