How to Prove the Sign-Preserving Property for a Continuous Function?
  • Thread starter Thread starter goodheavens
    Property
13 replies · 10K views
goodheavens
how do you prove the sign-preserving property?
it says here that.
If f is continuous at a, and f(a) < 0, then there is an open interval I containing a such that f(x) < 0 for every x in I.
For a proof, simply take the open interval (2f(a),0) for the challenge interval "J" in the definition of continuity.
i don't get it :(
:sorry my previous post was a mistake :)
Please show us your work.
The idea of the proof is to use the fact that if f is continuous at c and f(c)>0 then there exist a neighbourhood of c such that f(x) >0 .
That neighbourhood is what you have to find.
Try using the definition of continuity.
i saw a similar problem to this one and I am not sure if this works
using the [tex]\epsilon[/tex] - [tex]\delta[/tex] definition we have
l x-c l < [tex]\delta[/tex] [tex]\Rightarrow[/tex] l f(x) - f(c) l < [tex]\epsilon[/tex]
then they used [tex]\epsilon[/tex] = f(c)/2
lf(x)-f(c)l < f(c)/2
-f(c)/2<f(x)-f(c)< f(c)/2
f(c)/2 < f(x) < 3f(c)/2
f(x) > f(c) > 0 .
but i don't know how [tex]\epsilon[/tex] = f(c)/2
I have restored your second post because it is exactly what you want.
The whole idea of "continuity" is that "if x is close to a, then f(x) is close to f(a)." In particular, if f(c) is positive, and f(x) is close to f(c), then f(x) must be positive also.
Why f(c)/2? If f(c)> 0 then f(c)/2> 0 also so every number between f(c) and f(c)/2 is positive. Find [itex]\delta> 0[/itex] so that if [itex]|x- c|< \delta[/itex] (that is, so that [itex]c- \delta< x< c+ \delta[/itex], then [itex]|f(x)- f(c)|< f(c)/2[/itex]. That is the same as saying that [itex]-f(c)/2< f(x)- f(c)< f(c)/2[/itex] and, adding f(c) to each part, [itex]f(c)/2< f(x)< 3f(c)/2[/itex]. Since f(c)/2 is positive, so is f(x). In other words, f(x) is positive for all x in the interval [itex]c- \delta[/itex] to [itex]c+ \delta[/itex].
thank you sir
i forgot to mention that the interval was (a,b)
Your interval involves c and delta. (a, b) is simply the delta neighbourhood of c.
You cannot determine the interval in advance. Once you have found a "[itex]\delta[/itex]" for whatever [itex]\epsilon[/itex] you choose (as long as [itex]f(c)- \epsilon> 0[/itex]), [itex]a= c- \delta[/itex] and [itex]b= c+ \delta[/itex]
the interval (a,b) was actually one of the given data.
thank you
thank you
Well you changed the question! :-P
In the new question b does not exist.
The new question is a minor variation of the previous question. The only different is that c is now a and f(c) <0. This is okay since c was assumped to be abitrary.
The same prove you presented will work but your [itex]\epsilon = \frac{|f(a)|}{2}[/itex].
yeah cause its the same as in this https://www.physicsforums.com/showthread.php?t=460116 that would be double posting :)
so this is the final proof that i made for the previous question.
Let [tex]\epsilon[/tex] > 0
Since f(c) > 0. then [tex]\frac{f(c)}{2}[/tex] > 0 . use [tex]\epsilon[/tex] = [tex]\frac{f(c)}{2}[/tex]
l x-c l < [tex]\delta[/tex] [tex]\Rightarrow[/tex] l f(x) - f(c) l < [tex]\frac{f(c)}{2}[/tex]
c - [tex]\delta[/tex] < x < c + [tex]\delta[/tex] [tex]\Rightarrow[/tex] [tex]\frac{-f(c)}{2}[/tex] < f(x) - f(c) < [tex]\frac{f(c)}{2}[/tex]
[tex]\Rightarrow[/tex] [tex]\frac{f(c)}{2}[/tex] < f(x) < [tex]\frac{3f(c)}{2}[/tex]
[tex]\Rightarrow[/tex] f(x) > [tex]\frac{f(c)}{2}[/tex] > 0
Thus, f(c) > 0
if i made a mistake please tell me . thank you
This is correct.
Thus, f(c) > 0
Weren't you trying to prove that f(x) is greater than 0, using the fact that f(c) is greater than 0? It seems that your final statement should be "Thus, f(x)>0".
oh yeah. haha thank you :smile::
