How to Rearrange the Formula to Find Load Resistance?
  • Thread starter Thread starter Kobayashi
    Load Resistance
To find the load resistance (RL) given a power of 90W, the equation PL = (V^2 * RL) / ((RL + r)^2) is used, where r is the internal resistance. The internal resistance was calculated to be 5 Ohms with a supply voltage of 100V. Rearranging the formula involves multiplying both sides by the denominator, expanding, and then grouping like terms to form a quadratic equation. The correct approach requires using the supply voltage in the calculations. After correcting the algebra, the accurate load resistance values are determined to be 100.75 Ohms and 0.25 Ohms.
Kobayashi
[SOLVED] Calculate Load Resistance
Find RL if PL is 90W.
PL= ((V^2)*(RL))/((RL+r)^2)
I calculated the internal resistance to be 5 Ohms on my circuit with a supply voltage of 100V
So, 90W = ((100^2) * (RL))/((RL + 5)^2)
From this equation how do I rearrage the formula to get the Load Resistance?
Expand the square in the denominator, cross multiply it to the left side. Collect the linear terms (linear in RL) onto the left side, so the right is zero. This is now a standard quadratic equation, apply the quadratic formula to solve.
So,
R^2 + 2Rr + r^2 + 90 - (V^2*R)
Becomes,
R^2 + 10R + 115 - 10000R =0
R^2 + 9990R + 115 = 0
From this I still can't get the correct answer when using the quadratic formula. Is it the load voltage or the supply voltage you use in this case? The two answers should be 100.75 Ohms and 0.25 Ohms. Any idea where I'm going wrong?
You are messing up the algebra.
Starting with your first equation:
P_L= \frac{V^2R_L}{(R_L+r)^2}
You need to multiply through by the denominator so you get
P_L(R_L+r)^2 = V^2R_L
Now expand the bracket, and then multiply through by P_L. Group like terms and then use the quadratic formula.
Use the supply voltage.
Thanks, I now managed to get the correct answer.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
11K
