Solve for XYZ Given LMN: 0.5839, 0.1682, 0.2477
  • Thread starter Thread starter antienor
    Reverse
To solve for XYZ using the given LMN values (0.5839, 0.1682, 0.2477), the equations provided clarify that L, M, and N are simply labels for these numbers and do not indicate multiplication. The values of X, Y, and Z can be derived from the equation T = (1/X + 1/Y + 1/Z) * 100, where T is calculated as 109.0699. By rearranging the equations, X, Y, and Z can be isolated using the known values of L, M, and N. The notation confusion arises from the use of brackets and the labels, which should be clearly defined as L = 0.5839, M = 0.1682, and N = 0.2477 for clarity. Understanding this notation is essential for accurately solving for XYZ.
antienor
From the equation below,
how do we get the XYZ if the only numbers given are the LMN (0.5839, 0.1682, 0.2477)?
Thank you!
X = 1.57
Y = 5.45
Z = 3.70
T = (1/X+1/Y+1/Z)*100 = 109.0699
A = (1/ (X*T))*100 = (L) 0.5839
B = (1/ (Y*T))*100 = (M) 0.1682
C = (1/ (Z*T))*100 = (N) 0.2477
Mathematics news on Phys.org
I'm not sure if I understand your notation.
If you know (1/ (X*T))*100 = 0.5839 and T = 109.0699 then you can get X simply by multiplying both sides with X/0.5839. The other two variables work the same way.
Hi already edited my post. This clears everything? Thanks!
What does "= (L) 0.5839" mean? Is that a multiplication of L and 0.5839? Does that mean L has this value?
LMN is just like XYZ variables.
That doesn't answer my question. Is it a multiplication or something else?
Why are there brackets?
I just don't understand the notation.
I see, my bad! L doesn't represent any numbers from the equation and that's not multiplication. I just put L so that I can tell people that I need to get the XYZ from those numbers 0.5839, 0.1682, 0.2477, LMN are just labels for these numbers. No other significant role in the equation.
Sorry for making a mess in the equation!
Then you should write this as L = 0.5839, M = 0.1682, and N = 0.2477. When you write LMN or XYZ, most people would interpret these as L * M * N or X * Y * Z
  • · Replies 38 ·
11K
