How to seat a motor shaft B taper connector correctly?
  • Thread starter Thread starter abdulbadii
    Motor Shaft
To correctly seat a motor shaft B taper connector, such as B12, B16, or B18, it is important to apply an initial axial force during assembly, especially for applications like drilling machines or lathes. A quick impulse by hand can help secure the connection, and checking for slippage by attempting to turn the tool holder can indicate if it is properly seated. For larger drill bits, additional compression can be achieved by pressing the tool holder against a stable surface before starting the operation. Operators may also use tapping techniques with a wooden block for added security, but this should only be done when no drill bit is attached. Ensuring the connector is securely seated is crucial for reliable performance during operation.
abdulbadii
TL;DR Summary
How's actually to correctly seat most commonly B taper connector
Being so noob in taper connection, asking:
How do we correctly seat a motor shaft connector of B taper system, most commonly B12, B16, B18, into its chuck mate in such that if there's no bolt fastening axially in center it's still quite viable and reliable ?
it's just a press by a muscled hand, put weigh on top of connector after insertion, hit it gently or etc ?
Thanks much in advance
What's your application?
For applications that use axial compression, such as for drilling machines or lathes, the initial axial force for assembly is not too important as the more you press the tool against the part, the more torque you are able to naturally transmit. With those machines, I simply apply a quick impulse by hand:
and then I check whether I can turn the tool holder by hand or not, if I can't, then it's usually enough to start drilling without any slippages (if you can turn with your hand, then don't release the tool holder as it's going to fall out, just remove it and give it another impulse).
Also, when using larger drill bits (>12mm), with the machine off, I press the tool holder against the drilling table, jig or part, or the drilling tool itself against a high density rubber or wood block (also with the machine off), to give an extra compression just to be sure before I start drilling. Now with the machine on, I also bring the tool against the part very gently in the beginning to watch for any slippage and eccentricity, before putting more force or activating the automatic feed. This is done only for the first hole and every time the tool holder is replaced.
Example of using a tapping force (this is a bit painful, obviously it can only be used when there's no drill bit pre-assembled. Some operators use a wood stick or wood block instead of tapping with their own hand, and I used to operate much larger machinery so I didn't use this technique at all, but it covers your question as you mentioned it):
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
