How to set up a double slit experiment?
The discussion centers on setting up a double slit experiment, emphasizing the need for specialized equipment to emit particles one at a time and detect them accurately. Key components include a laser, CCD camera, and a vacuum system, with costs potentially exceeding $100,000 for a minimal modern rig. Participants suggest starting with a basic setup using a diode laser and a simple optical kit for hobbyists, while also highlighting the importance of laser safety and the challenges of achieving single photon detection.
  • Understanding of optical components such as lasers and CCD cameras
  • Knowledge of particle detection methods
  • Familiarity with basic optics and experimental physics
  • Awareness of laser safety protocols
  • Research "single photon sources" for advanced setups
  • Explore "basic optics kits for hobbyists" to gain foundational skills
  • Learn about "photomultiplier tubes" for low-intensity light detection
  • Investigate "laser safety guidelines" to ensure safe experimentation
Hobbyists interested in experimental physics, educators looking for practical demonstrations, and anyone exploring advanced optics and particle detection techniques.
Fiziqs
I was thinking of finding a new hobby, and thought that playing around with the double slit experiment might be interesting. I was wondering how feasible it would be to set up the double slit experiment, not simply the laser and slit version shown here: https://www.physicsforums.com/blog.php?bt=6320 , but with all the necessary apparatus to emit particles one at a time, detect them at the slits and then record them on a screen.
What equipment would be needed to set such an experiment up? Where can such equipment be purchased, and how cost prohibitive would it be? I'm allotting $5K for the initial setup, but I'm not sure what I could get for that amount of money. It just seems that the double slit experiment allows for such a broad spectrum of possible permutations that it could keep someone's interest for an extended period of time.
If such an endeavor is impractical, can anyone suggest an experiment that would be both practical on a limited budget, and versatile enough to allow for future upgrades?
I suspect that you have not allocated a big-enough budget - is your idea to do the experiment with matter?
You need a particle accelerator of some kind, and a vacuum system.
http://en.wikipedia.org/wiki/Davisson–Germer_experiment
http://www.nature.com/nnano/journal/v7/n5/fig_tab/nnano.2012.44_F1.html
http://www.nist.gov/nvl/jres.cfm
A minimal modern rig would not get you a lot of change from $100,000
(i.e. a TEM costs around $95000)
If you have good contacts, you can usually pick up old equipment though.
I could see myself investing $100k in a system at some point, but would like to start off more modestly. Would a simple setup of a laser, attenuator, barrier, ccd camera be sufficient to begin with? If so does anyone have any suggestions as to the type of components to use, and any accompanying components that might be necessary. What would be the best type of laser and ccd?
Thanks
The problem is that lasers do not emit single photons: they emit coherent radiation.
Hence, if you want to emit single photons you need to use various tricks, and these generally involve quite a lot of expensive equipment.
And no $100K is still not enough for this; $100K is probably just about enough to buy one of the lasers you would need. Setting up an optical lab from scratch would probably cost clsoer to a $1M (it obviously depends on what you are trying to do, but $1M is probably a good order-of-magnitude estimate).
I was thinking that the cost wouldn't be in the laser so much, but rather at the other end in the ccd. I've seen examples of the setup described using a simple 5Mw HeNe laser with maybe a filter, lens, and an attenuator, none of which appear to be all that expensive. As for the ccd, I found this one on ebay: http://www.ebay.com/itm/Photometrics-Cascade-1K-Megapixel-EMCCD-Camera-PVCAM-Power-Supply-PCI-Card-Cable-/111165006517?pt=LH_DefaultDomain_0&hash=item19e1f362b5, but I'm not sure if this one is what I would need. Or whether this one is insufficient, overkill, or wrong for my application. Which is why I was hoping for some educated input. What is it about the laser that I'm not getting. I don't need a true single photon emitter. I was thinking that a laser with an attenuator should work fine for my purposes.
What type of laser do I need for a hobbyist setup? What type of ccd?
Thanks
The basic bobby setup for diffraction would be a diode laser, a hair, and a wall.
Cost is about $20 or so.
You have indicated you are interested in low intensity stuff ... do you want to go low enough to have a single photon traverse the apparatus at a time?
So the laser is chosen usually for the frequencies you want.
To get down to one photon at a time - you need a "single photon source"
http://iopscience.iop.org/0034-4885/68/5/R04/
For very low intensity light, you need a photomultiplier.
The lower the intensity of the light, the more expensive the photomultiplier.
You also need a very dark room - if you are wanting to detect single photons you don't want any stray light at all if you can help it. Remember - everything gives off light at some level.
Starting to get the idea why it can get very expensive very fast?
U need to have a laser light and a card board with two pin holes very close to each other . And screen should be far away from the pin holes. Whole apparatus must be kept in dark..
In that case, I would recommend this setup:
http://video.mit.edu/watch/thomas-youngs-double-slit-experiment-8432/
Apparently OP is an advanced "hobbyist" who want to start at a substantially higher level with one particle at a time and be able to upgrade the equipment from there.
Good luck, Fiziqs.
Thanks for the good clip, Duplex! I will add that link to my blog post about DSE at home (which was mentioned in post #1). I also liked the suggestion on how to make good pin holes (in metal) - I will try that. It's difficult to make good circular pin holes in paper or cardboard - they easily distort the image:
Left: laser through one pinhole in paper, Right: laser through two pinholes in paper.
You may already have experimented with basic optics, I don't know. But if you haven't, I would personally start with buying and experimenting with a relatively cheap basics optics kit for hobbyists to see if I enjoyed it. And with a versatile kit you can do more than just the basic double slit experiment (lenses, mirrors, prisms, polarizers etc). You don't have to start with spending a fortune :wink:.
I also want to stress that lasers should be handled with care: Laser safety.
Maybe you can go and ask to use a university's optics lab for one hour or sth. Or you can join to an experimental physics class. It would be much more cheaper and educational I think.
  • · Replies 24 ·
  • · Replies 26 ·
  • · Replies 36 ·
  • · Replies 49 ·
  • · Replies 75 ·
  • · Replies 60 ·
  • · Replies 42 ·
  • · Replies 33 ·
