How to show a parametric equation is continuous?
A parametric equation r(t) is considered smoothly parametrized if its derivative is continuous and does not equal zero for all t in its domain. In the case of the tractrix r(t) = (t - tanh(t))i + sech(t)j, the derivative is calculated as r'(t) = (1 - sech(t))i + (-tanh(t)sech(t))j. Both sech(t) and tanh(t) are continuous for all real t, but at t = 0, r'(0) equals zero, indicating that r(t) is not smoothly parametrized at that point. Therefore, r(t) is smoothly parametrized for all t except t = 0. The discussion emphasizes the importance of analyzing the continuity of the components of the derivative to determine smooth parametrization.
WalkingInMud
A parametric equation, say r(t), is smoothly parametrized if:
1. its derivative is continuous, and
2. its derivative does not equal zero for all t in the domain of r.
Now that sounds simple enough. Now let's say we have the tractrix:
r(t) = (t-tanht)i + sechtj, ...
then r'(t) = [ 1/(1+x^2) ]i + [ tantsect ]j, right?
Now, without reverting to MatLab or Maple to view the graph, how do we mathematically explain that r'(t) is continuous (or not)?
Do I just state that is is/isn't -by inspection, or ...?
No, not right. r'(t)= [1- sech t]i- tanh t sech t j/b]. I don't know why you have changed to "x" in the first component but you surely should not have tan and sec rather than tanh and sech in the second component.
A vector valued function is continuous if and only if its components are continuous. Where are sech t and tanh t continuous?
How does this look?
r(t)=(t-tanht)i+(secht)j ...so
r'(t)=(1-secht)i+(-tanhtsecht)j
Now, secht is continuous for all real t, and also
tanht is continuous for all real t, BUT...
since tanh(0)=0 i.e. (-tanhtsecht)=0 for t=0, and furthermore sech(0)=1 i.e. (1-secht)=0 for t=0,
...r'(0)=0 so r(t) is smoothly parametrized for all t NOT EQUAL TO 0
Is this OK?
Is this OK?
Yes, that is correct. And if you look at the graph of the tractrix, you can see what happens at t= 0.
