How to show span(U₁∪...∪Uₖ₋₁) + Uₖ = span(U₁∪...∪Uₖ)
  • Level: Undergrad
  • Thread starter Thread starter JD_PM
    Span
10 replies · 2K views
JD_PM
TL;DR
I want to prove that ##U_1 + U_2 + ... + U_k = span (U_1 \cup U_2 \cup ... \cup U_k)## by induction
1) Base case ##k=2##
##U_1 + U_2 = span (U_1 \cup U_2)##, which I understand how to prove is OK.
2) Induction hypothesis
We assume that the following statement holds
$$U_1 + U_2 + ... + U_{k-1} = span (U_1 \cup U_2 \cup \ ... \ \cup U_{k-1})$$
3) Induction step
$$U_1 + U_2 + ... + U_k = \underbrace{U_1 + U_2 + ... + U_{k-1}}_{=span (U_1 \cup U_2 \cup \ ... \ \cup U_{k-1})} + U_k = \ ? $$
But my issue is that I do not see how to move from ##span (U_1 \cup U_2 \cup \ ... \ \cup U_{k-1})+U_k##
Might you guide me on how to proceed further?
Thanks! :biggrin:
To prove two sets, ##A## and ##B##, are equal you often show that ##x \in A## implies ##x \in B## and vice versa.
Hi @PeroK !
Oh, I see! So let's forget about induction.
We take ##x=u_1 + u_2 + \dots + u_k \in U_1 + U_2 + \dots + U_k## where ##u_i \in U_i##.
Given that each element ##u_i## is found exclusively in ##U_i##, there is no difference between ##U_1 + U_2 + \dots + U_k## and ##U_1 \cup U_2 \cup \dots \cup U_k##. (let me know if you disagree with this statement).
Taking a linear combination of the elements ##u_1 + u_2 + \dots + u_k## leads to ##x = \sum\limits_{j = 1}^k \beta_j u_j \in span (U_1 \cup U_2 \cup \dots \cup U_k)##
Let's now go the other way and take ## x = \sum\limits_{j = 1}^r \beta_j u_j \in span (U_1 \cup U_2 \cup \dots \cup U_k)##. Next we construct sets: let ##K_1## be the set of indices ##j## such that ##u_j \in U_1##, ##K_2## be the set of indices ##j## not in ##K_1## such that ##u_j \in U_2## and so on up to ##u_j \in U_k##
Given that ##K_i## sets are disjoint, ##x = \sum\limits_{i = 1}^n \sum\limits_{j \in K_j} \beta_j u_j## and ##\sum\limits_{j \in K_i} \beta_j u_j \in U_i##, we get ##x \in U_1 + U_2 + \dots + U_k##
How do you see it? :)
PS: For what kind of proofs is best to use induction though?
JD_PM said:
Hi @PeroK !
That approach could apply to the inductive step!
OK I misunderstood you then. Do you have any comments on #3 though? Or you want me to focus only on induction.
JD_PM said:
Hi @PeroK !
Are you sure that the ##U_i## are disjoint? Are they not just any subspaces?
What I might have tried to do is to take ##x \in span(U_1 \cup \dots U_{k+1})## and show that ##x = u + u_{k+1}##, where ##u \in span(U_1 \cup \dots U_{k})## and ##u_{k+1} \in U_{k+1}##.
Then the inductive step should follow. Induction should simplify things, although it's the same basic idea.
A more detailed proof without using induction can be found here.
I still think that using induction simplifies things. In particular, all we really need to show is that:
$$span(U_1 \cup \dots \cup U_{k+1}) = span(U_1 \cup \dots \cup U_k) + U_{k+1} $$
The RHS is clearly a subset of the LHS, so we need to show that:
$$v \in span(U_1 \cup \dots \cup U_{k+1}) \ \Rightarrow \ v \in span(U_1 \cup \dots \cup U_k) + U_{k+1}$$
An outline of the proof is that for such a vector ##v##, we take all the terms that involve vectors in ##U_{k+1}## and (using the fact that ##U_{k+1}## is a subspace) recognise that this gives a single element of ##U_{k+1}##. We also recognise that what is left is an element of ##span(U_1 \cup \dots \cup U_k)##.
You can formalise this easily. And this should be simpler than having all those different sets of indices.
Thanks for the clarification @PeroK !
Let me check my understanding :)
OK so let us start by taking ##v \in span(U_1 \cup \dots \cup U_{k+1})##. Based on the definition of span, ##v = \sum\limits_{j = 1}^{k+1} \beta_j u_j = \sum\limits_{j = 1}^{k} \beta_j u_j + \beta_{k+1} u_{k+1}##. The first and second terms equal (by definition) to ##span(U_1 \cup \dots \cup U_k)## and ##span(U_{k+1})## respectively. Since ##U_{k+1}## is a subspace, it is closed under linear combinations so ##span(U_{k+1}) \subseteq U_{k+1}##. But by definition of span, we also have ##U_{k+1} \subseteq span(U_{k+1})##. Hence ##U_{k+1} = span(U_{k+1})## and indeed we see that ## v \in span(U_1 \cup \dots \cup U_k) + U_{k+1}##
It's more general than than: $$v = \sum_{j = 1}^n \beta_jv_j$$where ##v_j \in U_1 \cup \dots \cup U_{k+1}##. Now, we let $$u_{k+1} = \sum_j \beta_jv_j$$ where we sum over all ##j## where ##v_j \in U_{k+1}## and let $$u = \sum_j \beta_jv_j$$ where we sum over all ##j## where ##v_j \notin U_{k+1}##. This gives us $$v = u + u_{k+1}$$, where ##u \in span(U_1 \cup \dots \cup U_k)## and ##u_{k+1} \in U_{k+1}##, hence:
$$v \in span(U_1 \cup \dots \cup U_k) + U_{k+1}$$
That can be used in your inductive step.
Note also that the base case for ##k = 1## is that we have ##span(U_1) = U_1##.
