How to show that the motion graph of a linear oscillator is an ellipse.
The discussion focuses on demonstrating that the motion graph of a linear oscillator is an ellipse. For an undamped oscillator, participants derive the equation x²/A² + v²/(Aw)² = 1 by eliminating time from the equations of motion. They clarify that to show damping effects, one must introduce a damping constant into the motion equation, leading to a spiral trajectory toward the origin. Participants emphasize that finding the velocity involves taking the derivative of the position function x(t). The conversation concludes with a clear understanding of the relationship between position and velocity in the context of oscillatory motion.
RockenNS42
The motion of a linear oscillator may be represented by means of a graph in which x is abscissa and dx/dt as ordinate. The histroy of the oscillator is then a curve
a)show that for an undamped oscillator this curve is an ellipse
b) show (at least qualitatively) that if a damping curve is introduced on gets a curve spiraling into origin.
a) I got that
x(t)=Asin(wt-α)
v(t)=wAcos(wt-α)
Another student told me to "elimate the t's" to get
x2/A2 +X2/(Aw)2 =1
and that is total energy is E=1/2KA2 and w2=k/m then
x2/(2E/k) +X2/(2E/m) =1First of all, I don't under stand how eliminated his t's. I do get that he found the eq of an ellipse, but how do I go from an eq with X and w to one with x and dx/dt?
b)I have no sweet clue
I suspect that his answer should read
<br /> \frac{x^2}{A^2} + \frac{v^2}{A^2w^2} = 1<br />
To arrive at this rearrange the x and v equations so that only the sin and cosine functions are left on the right hand side. Then square both equations and add. \
For part b you will want to add a damping constant to the equation of motion:
<br /> m \frac{d^2x}{dt^2} = -kx - c \frac{dx}{dt}<br />
You will need to find solutions to this equation. From there you can find v, and plot x vs v.
Ok a) makes total sense now
b) In is c the damping constant? (we're using b) we have found in class that the solution to his comes in the fourm Aej(pt+α) is this what you mean?
Yep, that's what I'm talking about.
Ok then but I am still not sure where v is going to come from...
Once you solve for x(t) then the velocity is just the derivative.
Oh right. I get it. Thanks a lot :)
  • · Replies 26 ·
  • · Replies 33 ·
