How to Simplify an Integration Using Trigonometric Substitution?
  • Thread starter Thread starter KFC
    Integration
7 replies · 2K views
KFC
There is a integration need to be done
[tex]I = \int_{-\infty}^\infty \frac{1+x^2}{1+x^4}dx[/tex]
2. The attempt at a solution
I use the following substitution
[tex]x=\tan \theta[/tex]
such that
[tex]dx = \frac{d\theta}{\cos^2\theta}[/tex]
Now the integration becomes
[tex]I = \int_{-\pi/2}^{\pi/2} \frac{1}{1-0.5\sin^2(2\theta)}d\theta[/tex]
But I still stuck with the simplified integration. Any other way to do that?
Hi KFC! :smile:
Hae you tried factorising 1 + x4 and using partial fractions?
tiny-tim said:
Hi KFC! :smile:
Thanks a lot for your reply. I try to do something like that
[tex]1+x^4 = (1+x^2)(Ax^2 + Bx + C)[/tex]
and figure out A, B and C by comparing it to 1+x^4, but it will gives a complex terms.
There are two quadratic real polynomials whose product is (x^4+1). To my mind the easiest what to find them is to factor (x^4+1)=(x-c1)(x-c2)(x-c3)(x-c4) over the complex numbers and then pick the pairs where ci and cj are complex conjugates and multiply them to get the quadratic factors. Can you do that? There might be tricks you can use to stay in the real numbers, but I don't know them offhand.
Nooo … 1+x2 is not a factor of 1+x4.
As Dick :smile: says, roots come in complex conjugate pairs,
so x4 + 1 = (x2 + Ax + B)(x2 + Cx + D), with A B C and D real. :wink:
As Dick mentioned, there's also a little trick possible if you notice that
x4+1 = (x2+1)2-2x2
Now you can just use the factorization of a difference of two squares.
The factoring is simpler to get if you add and subtract [itex]2x^2[/itex] to the denominator and you those 6th grade formulas for expanding the square of a sum and the difference of two squares...
Thanks all of you guys, it helps. I know how to do it now. :)
