How to simulate lognormal distributions?
  • Context: Undergrad
  • Thread starter Thread starter jackaip
    Distributions
3 replies · 12K views
jackaip
I am studying statistics and am interested in understanding the log normal distribution. From some discussion I gather that the log normal distributions arises from multiplicative effects while the normal distribution arises from additive effects. I generated the following MATLAB code to simulate the normal distribution.
clear
for j = 1:10000
S = 0;
for i = 1:1000
S = S + rand(1)-0.5;
end
T(j) = S;
end
hist(T,100)
If you add a bunch of random numbers between -0.5 and 0.5 you get more or less a gaussian
by the central limit theorem.
Now I am interested in simulating the log normal distribution, but not sure what to do. Has anyone ever tried this. I saw that if the variance grows in time in certain stock market models you can get a log normal distribution. Also the number of proteins in cells is more or less log normal distributed.
Thanks,
jackaip
If you generate [itex]X[/itex] as a normal random variable then [itex]e^X[/itex] is a lognormal random variable.
You should look at better algorithms for generating normal random variates. I don't know them by memory, but if I happen to run across one, I'll post it.
clear
for j = 1:10000
S = 0;
for i = 1:1000
end
T(j) = S;
end
hist(T,100)
Thanks,
jackaip
Hey jackaip.
If you can simulate a normal variable (if you don't have a tool, use R: it's free and you will able to do what you need in 5 minutes), then simply simulate a normal and then calculate a new variable which is eX which basically calculates the exponential of each realization created and stores this in another vector. This vector will be log-normally distributed.
In R, this will look like:
x = rnorm(10000,0,1)
lognorm = exp(x)
hist(lognorm)
This will produce a histogram. If you want actual values just use lognorm and reference each component at location i using lognorm.
If you need to do this in MATLAB, then basically generate a simulated normal and then just apply exp(x) where x is each generated value and throw that in a vector.
Hi All!
lognorm = exp(x)
hist(lognorm)
In fact R already has the log-normal distribution implemented, so simply rlnorm will suffice to generate those samples.
And as for jackip's question, the algorithm to generate the normal distribution, in your code:
Code:
for j = 1:10000
   S = 0;
   for i = 1:1000
   end
   T(j) = S;
end
You are using a random walk to generate the normal distribution which is extremely inefficient as well as inaccurate, so, I guess you do this not because you don't know better but rather because this way you can see how a normal distribution is constructed and, likewise, you'd like to see again how the log normal is constructed. Am I right?
Well, if this is so you just need to change this T(j) = exp(S) in your code to converge to a log-normal distribution and, since S is a summatory, you can turn it into the following construction:
Code:
for j = 1:10000
   S = 1;
   for i = 1:1000
      S = S * exp(rand(1)-0.5);
   end
   T(j) = S;
end
Which is even more inefficient and inaccurate but it gives you the rough understanding on how a log normal distribution is constructed which I guess is what you're looking for. right?
