How to size motor for compressor
8 replies · 10K views · last reply
martian212
HI - I'm looking for some help. I'm trying to design a low flow single piston reciprocating compressor. Here is what I have:
-Piston bore diameter- 1.50 in
-stroke- 0.100"
-should be able to go up to 30 psig
average pressure will be 20psig
-I am looking for the air flow to be 4.00 lpm at a back pressure of 20 psig
-I believe the rpm of the motor should be about 2700 rpm
How do I calculate what torque will be required at a back pressure of 20 psig and obtain a flow of about 4 LPM.
I would really appreciate the help.
Thanks!
One more thing-I plan to use a brushless dc motor for this design
You are not going to get much compression with a piston that has a stroke of only 0.100". Please check all dimensions of your compressor.
All the dimensions are correct. The stroke is so small because I do not need that much flow.
You can work that out roughly by energy method. Power = ρgQH = Tω.
You are asking for 30 psig. This is 15 psia to 45 psia, a 3:1 compression. I doubt that you can get this with a 0.100" stroke, when you consider the whole volume that is getting compressed. Are you planning to use 1-way check valves, or is the compressor an overhead valve machine?
True, I may have to up-stroke. I am planinning to use a flapper which is similar to a one way check valve. Any thoughts on what my required torque would be? Or how to calculate it?
Don't you have TWO flapper check valves, one on the input and the other on the output? The total compression stroke you have is 0.177 cubic inches with a 0.1" stroke. The TOTAL compressed volume between flapper chsck valves has to be about 33% (or less)of 0.177 cubic inches. How close (in mils) will the piston be to the top of the compression chamber at the top of the stroke? 10 mils? How sacred is your 1.5" piston diameter?
