How to Solve an Integral Equation Involving Exponential Functions?
The discussion revolves around solving an integral equation involving exponential functions, specifically focusing on the equation \( f(t) = e^t + e^t \int_0^t e^{-\tau} f(\tau) d\tau \). Participants explore various methods to approach the problem, including algebraic manipulation and iterative solutions.
  • Homework-related
  • Some participants seek clarification on the form of the integral equation and the unknown function \( f(\tau) \).
  • There is a suggestion to transform the integral equation into a differential equation or to solve it directly through iteration.
  • One participant proposes defining \( g(t) = e^{-t} f(t) \) and reformulating the equation as \( g(t) = 1 + \int_0^t g(\tau) d\tau \).
  • Another participant describes an iterative approach starting with \( g^{(0)} = 1 \) and computing subsequent iterations to approximate \( g(t) \).
  • Participants discuss the importance of distinguishing between the variables \( t \) and \( \tau \) in the context of integration.
  • There is mention of the Maclaurin expansion of \( e^t \) as a means to derive \( g(t) \) and subsequently \( f(t) \).
Participants generally agree on the steps to manipulate the integral equation and the iterative approach, but there is no consensus on the complete solution process, as some participants express confusion about specific steps.
Some participants indicate uncertainty about the transformation steps between equations and the iterative process, highlighting the need for clarity in the definitions and operations involved.
Sunny29
Member warned that homework questions must be posted in the Homework sections
Please anyone can help solve this integral equation
e^t+e^t ∫ (t, 0 ) e^(-τ) x f(τ) dτ
What have you tried? And what is f(τ)?
Well one can never be sure but I suppose f(t) is the unknown function we wish to find. But first things first, is the equation we trying to solve as follows
##e^t+e^t\int_0^t {e^{-\tau}f(\tau)d\tau}=0##?
Sorry, i haven't tried because i am not understanding the question completely.
No, it is not equal to 0.
The question is exactly like this
"Solve the Integral Equation
f(t)= same as you have written
Ok so the equation is
##f(t)=e^t+e^t\int_0^t {e^{-\tau}f(\tau)d\tau}##.
First do some algebraic operations and write the equation in the form ##\int_0^t {e^{-\tau}f(\tau)d\tau}=...##
Now what operation can you apply at that form (hint: then plan is to convert the integral equation to an ordinary differential equation, there might be other ways to do this problem)
It is easy to show that the equation can be transformed to the form
$$g(t)=1+\int_0^t g(\tau)d\tau$$,
where
$$g(t)=e^{-t}f(t)$$.
The equation can as mentioned before be transformed to a differential equation. A more simple way is however to solve it directly by iteration, i.e.
$$g^{(n)}(t)=1+\int_0^t g^{(n-1)}(\tau)d\tau$$.
The iteration is started by using ##g^{(0)}=1## and then computing ##g^{(1)}##, ##g^{(2)}##, etc. After a few iterations it should be obvious what ##g(x)## is.
where
Dear,
Could you please solve the complete answer step by step? I am having difficulty in understanding.
Thanks..!
As, I understand it is against the rules at this forum to give a complete answer to the problem. You need to show the work you have done.
But, if you tell me which step you don't understand I will be happy to help. So, which step do you don't understand?
okay no problem. you just tell me how you write the first step and how you put the 1.?
You have the equation
$$f(t)=e^t+e^t\int_0^{t}e^{-\tau}f(\tau)d\tau\quad (1)$$
Do you understand how to go from Eq. (1) to
$$g(t)=1+\int_0^{t}g(\tau)d\tau\quad (2) $$,
where ##g(t)=e^{-t}f(t)## ?
No, i can't understand how to go from Eq 1. to Eq 2.
Also, i am bit confusing between "Tau" and "t"
Multiply both sides of Eq. (1) by ##e^{-t}## and then simplify. What do you get?
Both ##t## and ##\tau## are variable. For each value of ##t## we have one a left-hand side an integration from ##0## to ##t##. Therefore, to not mess things up we need to introduce an integration variable called ##\tau##. Obviously, the name of the variable is arbitrary.
yes i have got. now what is after the iteration step? g(x)=?
As, I understand you now got Eq. (2). Now, we want to solve this by iteration.
On the left-hand side we start by a "guess" for ##g(\tau)##. As, the inhomogeneous term is 1. We start by putting ##g(\tau)=1## on the left-hand side.
You now compute a better estimate ##g(t)## from the equation. This should give you ##g(t)=1+t##.
Now, in the next step we put ##g(\tau)=1+\tau## on the left-hand side and calculate a new ##g(t)##. This procedure should lead to
$$g(t)=1+t+t^2/2+t^3/6+...$$
Do you get this?
Do you get this?
Yes, for sure i understand this also..
Does it ends here or something remaining?
eys_physics said:
Now, if you recall the Maclaurin expansion of ##e^t##, see https://en.wikipedia.org/wiki/Taylor_series , it follows
##g(t)=e^t##.
From this we obtain ##f(t)##.
Yes i have solved it. And thank you very much for your help.
You are welcome.
  • · Replies 27 ·
  • · Replies 21 ·
