How to solve for x and y with Lagrange functions?
  • Thread starter nikk834
    Lagrange
9 replies · 3K views · last reply
nikk834
if you have dl/dx= -2 +0.002x-lagrange function(backword L)
dl/dy=0.012y-5-lagrange function
dl/dl= -(x+y-2000)
How do you solve for x, y and backword l?
Is this problem about maximizing or minimizing a function subject to a constraint? If so, what are the function and constraint? I'm asking because I'm not convinced your partial derivatives are correct.
dl/dl= -(x+y-2000)
Hi Vela , here is the problem that i am asked to solve.
The costs incurred by the company are denoted as follows:
R(x,y) = 7,500 -2x +0.006y^2-5y+0.001x^2
The company has a total of 2,000 knitting hours available each year, representing a constraint as follows:
x+y = 2,000
The company wishes to determine how to allocate the hours of operation between the two sweaters while minimizing cost.
(a)
Using the method of Lagrange, determine how many hours to allocate to each sweater.
(b)
Using the optimal hours determined above, what is the total cost?
OK, so what I gather you did so far was to construct this function:
[tex]L(x,y,\lambda) = 7000-2x+0.006y^2-5y+0.001x^2-\lambda(x+y-2000)[/tex]
and took the partial derivatives. (The "backward L" is the Greek letter lambda.)
When you take the partial derivative with respect to x, for example, you have to also differentiate the term representing the constraint, so you'd get
[tex]\frac{\partial L}{\partial x}=-2+0.002x-\lambda[/tex]
Once you get the derivatives, to find the extrema, you set the partial derivatives to zero and solve the equations.
Hi Vela,
I have done that so far and gotten 3 functions:
dl/dx=-2 + 0.002x-Langrange
dl/dl=-(x+y-2000)
I do not know how you would go about solving these equations but i know the solutions are x =1500 y=500 and lagrange=1
How exactly do you solve?
Like I said, you set them equal to zero so you actually have equations to solve:
[tex]-2+0.002x-\lambda=0[/tex]
[tex]-5+0.012y-\lambda=0[/tex]
[tex]x+y-2000=0[/tex]
If i solve it comes out to
0.002x=2L
this comes out as 1000 which is not right
and the next one comes out to 0.012y=5
this comes out to 416 which is not right
You're not doing the algebra correctly. The first equation should become
[tex]0.002x = \lambda+2[/tex]
for example. Try solving for lambda in the first equation, and then substitute that into the second equation, so you just have x's and y's. Then solve for either x or y and substitute that into the last equation.
ok so lamda=2-0.02x
if i substitude that into the next equation i get 0.012y-5-2-0.02x
how do i solve for that when i got 2 variables x and y.
nikk834 said:
ok so lamda=2-0.02x
You can't solve that since, for one, it's not an equation. What does that expression equal? Once you have that sorted out, remember that you still have one more equation you can use to help you solve for x and y.
