How to Solve These Vector Field Equations?
  • Context: Undergrad
  • Thread starter Thread starter Unit
5 replies · 24K views
Unit
x'' = y; y'' = -x?
I'm working on vector fields and I've got these two equations; no teacher in my high school knows what to do from here.
initial conditions:
t = 0
x, y = 0, 1 (the initial position)
dx/dt = 0
dy/dt = 0
[itex]\frac{d^2x}{dt^2} = y[/itex]
[itex]\frac{d^2y}{dt^2} = -x[/itex]
How do I solve this?
Thanks a bundle :)
-Unit
Your title gives one system and your post gives a different one. I assume your system is
x'' = y
y'' = x
plus your initial conditions. Differentiate the first equation twice:
x'''' = y'' = x, so you have:
x''''(t) - x(t) = 0.
This is a constant coefficient equation with characteristic equation:
r4 - 1 = 0.
Do you know how to write the solution for x(t) from that? If so, then you can use
y = x''
to get y. Plug in your initial conditions along the way to keep it simple.
Yes, sorry for the discrepancy. Your assumption was right, I was indeed talking about x'' = y and y'' = -x. I fixed the thread title!
And omgsh that makes perfect sense! I was thinking I had to make a substitution of sorts, something crazy with polar coordinates or something. The fact that it's a fourth derivative equaling the first derivative makes it look like a sine/cosine function!
I'll work on the answer now, using r^4 - 1 = 0, thank you :)
Waiiiiiit. x''''(t) = -x(t)
x''''(t) + x(t) = 0
That is what I'm solving. Does this make any difference?
initial conditions:
t = 0
dx/dt = 0
dy/dt = 0
Thanks a bundle :)
-Unit
I would rather convert the problem to the following IVP and solve
[tex]\frac{dZ}{dt} = AZ[/tex]
subject to Z(0)=(0 0 1 0)t
where
[tex]A = \left(\begin{array}{cccc}0&1&0&0\\<br /> 0&0&1&0\\<br /> 0&0&0&1\\<br /> -1&0&0&0\end{array}\right) [/tex] [tex]Z = \left(\begin{array}{c}x\\ \dot{x}\\ y \\ \dot{y} \end{array}\right) [/tex]
