How to solve this Sudoku without guessing
  • Level: High School
  • Thread starter Adel Makram
    Logic Sudoku
11 replies · 3K views · last reply
Adel Makram
How to solve the attached Sudoku without computer or a guess?
  • Partially filled 9 by 9 Sudoku grid. Top row reads 9, 2, 1, 3, 8, 4, 7, 6, 5. Right column has 4, 8, 1, 3, 9, 7, 6, 2 in rows 2 to 9; other cells are blank.
This sudoku does not have a unique solution, in-fact it has at-least 500 solutions, therefore it is not possible to solve it purely based on logic. (By this I mean you will have to make a choice.)
How do I know it has at-least 500 solutions ? Click the solution-count button http://www.sudokuwiki.org/sudoku.htm. [I've done you the courtesy of typing out the sudoku.]
I clicked the link and I filled up the entries then it gave me all numbers (1 to 9) in all blank cells!. So how many solutions?
But I'd already filled the necessary squares for you ?
Click the yellow "solution-count" button at the top right.
yes I got it thanks. So what is the lowest number of clues that give a unique solution?
If it has "at least 500 solutions" then it does not have a unique solution!
Oops! I misread your response- you did say it does NOT have a unique solution.
willem2 said:
According to http://arxiv.org/abs/1201.0749, no solvable sudoko exists with less than 17 clues. Your sudoku is actually a 16 clue sudoku, because the 5 in the top right corner is redundant.
What do you mean by redundant?
He means you already know it is 5, it's not a useful information.
Note that 17 clues does not guarantee a unique solution, but you need at-least 17, as the paper quoted by willem2 shows.
It's actually only a 12 clue sudoku. You should be able to enter the remaining entries from this.
Still, I don't understand why do you want to consider all entries on the right upper square redundant? Just because they are on 2 perpendicular lines?
No. They aren't clues because you can solve the empty entries in the link from the given ones.
