How to Store User Input as Memory in MIPS Assembly
The discussion revolves around writing a MIPS assembly routine that accepts two integers, calculates their quotient and remainder, and generates a formatted string to display the results. Participants explore the implementation details, including how to store user input and format the output string correctly.
  • Homework-related
  • Some participants express confusion about how to format the output string to include both the input integers and the calculated results.
  • There is a discussion about whether the integers should be stored as strings or as numeric values, with some participants suggesting that the current data segment is misleading.
  • One participant proposes a restructuring of the data segment to clarify the storage of integers versus strings.
  • Another participant indicates that they have figured out how to include the quotient and remainder in the output but are still uncertain about incorporating the original input integers.
Participants generally agree on the need to clarify how integers are stored and used, but there is no consensus on the best approach to formatting the output string or the exact implementation details.
Some participants note that the initial variable names may imply incorrect usage, leading to confusion about whether they are intended for storing integers or strings. There are also unresolved questions about how to properly format the output string with the required values.
lina29
Write a routine that accepts two integers i and j as arguments, calculates the quotient and remainder of i and j, and generates a string in memory that stores "The quotient of i and j is i/j and the remainder is i%j". For example if the arguments was 15 and 7 the string in memory would be "The quotient of 15 and 7 is 2 and the remainder is 1". The address of the string is returned as the 3rd argument of your routine. Write a main program that calls your routine, test run it using MARS and show the output.
# division.asm
.data
intI: .asciiz "\nEnter i: "
intJ: .asciiz "\nEnter j: "
quotient: .asciiz "\nThe quotient is = "
remainder: .asciiz "\n\nThe remainder is = "
.text
main: li $v0, 4 # system call code for print_string
la $a0, intI # address of intI
syscall # print intI
#get the first number from user, put it into $s0
li $v0, 5 # system call code for read_int
syscall # read an integer into $v0 from console
add $s0, $v0, $zero # copy $v0 into $s0 #read print_string for str2
la $a0, intJ # address of intJ
syscall # print str1
# get second number from user, put it into $t1
li $v0, 5 #load syscall for read_int
syscall #make the syscall
move $s1, $v0 #move the number read into $s1div $s0, $s1 #diving $s0 by $s1
mflo $t0 #storing value of lo(quotient) in
#register $t0
mfhi $t1 #storing value of hi(remainder) in
#register $t1
mult $s0, $s1
mflo $t2li $v0, 4 # Print string
la $a0, quotient # address of quotient
syscall
#print a/b
li $v0, 1 #load syscall print_int into $v0
move $a0, $t0 #move the number to print into $t2
syscall
# read print string for remainder
li $v0, 4
la $a0, remainder
syscall
# print remainder
li $v0, 1
move $a0, $t1
syscall
#end of program
li $v0, 10 #system call code for exit
syscallWhat I'm having a problem with is the output. I'm not sure how I'm supposed to do "For example if the arguments was 15 and 7 the string in memory would be 'The quotient of 15 and 7 is 2 and the remainder is 1' "
Also am I storing the numbers as strings not integers?
# division.asm
.data
.text
#register $t0
#register $t1
mult $s0, $s1
mflo $t2
syscall
#print a/b
syscall
li $v0, 4
la $a0, remainder
syscall
# print remainder
li $v0, 1
move $a0, $t1
syscall
#end of program
syscall
I wouldn't store the numbers as strings.
To get the output you need you'll need to display several strings and four numbers.
str1 - "'The quotient of "
str2 - " and "
str3 - " is "
str4 - " and the remainder is "
str5 - "."
num1 - 15
num2 - 7
num3 - 2 (your program calculates this)
num4 - 1 (and this)
Use the appropriate syscall for printing a string to display each of the five strings in the right order, with syscalls in the right places for printing an int.
# division.asm
.data
str1: .asciiz "\nThe quotient of "
str2: .asciiz "and "
str3: .asciiz "is "
str4: .asciiz " and the remainder is "
str5: .asciiz "."
.text
add $s0, $v0, $zero # copy $v0 into $s0 #read print_string for intJ
#register $t0
#register $t1
mult $s0, $s1
mflo $t2 li $v0, 1 #load syscall print_int into $v0
syscall
li $v0, 4
la $a0, str1
syscall
li $v0, 4
la $a0, str2
syscall
li $v0, 4
la $a0, str3
syscall
# print quotient
li $v0, 1
move $a0, $t0
syscall
li $v0, 4
la $a0, str4
syscall
# print remainder
li $v0, 1
move $a0, $t1
syscall
li $v0, 4
la $a0, str5
syscall
#end of program
syscall
I figured out how to put the remainder and quotient into the string. I'm still confused on how I would add i or j into the string. Are my numbers stored as strings? Based on the prompt I though that's what it was asking
You need to store the two input integers in memory. Your data segment is somewhat confusing as you have intI and intJ as variables. Their names would suggest that they are to be used to store integer values. Instead, you have strings stored in them.
I would set things up more like this:
Code:
.data
intI: .word 0
intJ: .word 0
prompt1: .ascii "\nEnter i: "
prompt2: .ascii "\nEnter j: "
str1: ...
etc.
To be honest I'm still having trouble
Code:
# division.asm
  .data
intI: .word 0
intJ: .word 0
str3: .asciiz "is "
str5: .asciiz "."
  .text
  la   $a0, prompt1      # address of intI
  #la $a1, prompt1 #gets the length of the space in $a1 so we can't go over the memory limit
  syscall
  la   $a0, prompt2        # address of intJ
                #register $t0
                #register $t1
mult $s0, $s1
mflo $t2                #li  $v0, 1      #load syscall print_int into $v0
#move $a0, $t0   #move the number to print into $t2
#syscall
li $v0, 4
la $a0, str1
syscall
li $v0, 4
la $a0, str2
syscall
li $v0, 4
la $a0, str3
syscall
# print quotient
li $v0, 1
move $a0, $t0
syscall
li $v0, 4
la $a0, str4
syscall
# print remainder
li $v0, 1
move $a0, $t1
syscall
li $v0, 4
la $a0, str5
syscall
#end of program
syscall
Right now my code is printing out
Enter i:
Enter j:
The quotient of
before it even let's me enter the first integer. I know I need to store the two integers as memory I'm just completely lost on how to approach it. Is there any specific command I should use?
  • · Replies 22 ·
21K
11K
14K
