How will a ceiling extract valve affect a radiator?
  • Thread starter Thread starter TSN79
    Radiator Valve
The presence of a ceiling extract valve directly above a 1000 W radiator, which extracts air at a rate of 35 m3/h, poses a significant risk to the radiator's efficiency. The hot air generated by the radiator will be drawn directly into the extract valve, preventing proper circulation throughout the room. This configuration can lead to inadequate heating and discomfort in the living space, particularly if the room size and makeup air source are not properly accounted for.
  • Understanding of radiator heating systems
  • Knowledge of ventilation principles
  • Familiarity with airflow dynamics
  • Basic concepts of room heating requirements
  • Research effective radiator placement strategies
  • Learn about balancing heating and ventilation systems
  • Investigate the impact of airflow on heating efficiency
  • Explore solutions for optimizing room heating with extract valves
Homeowners, HVAC professionals, and interior designers looking to optimize heating efficiency and ventilation in residential spaces.
TSN79
An apartment has a radiator, about 1000 W. Nearly right above it is an extract valve for the ventilation system which extracts 35 m3/h. The vertical distance between the two is around two meters. Is there a risk that this will prevent the radiator from functioning properly as the hot air will just go straight into the extract valve instead of finding its way around the room?
Yes.
How big of a room is it? What is the source of makeup air?
  • · Replies 26 ·
  • · Replies 26 ·
10K
  • · Replies 39 ·
15K
  • · Replies 152 ·
11K
11K
  • · Replies 21 ·
