How's it possible that 70% of Earth receives sunlight simultaneously
  • Context: High School
  • Thread starter Thread starter yohananregal
    Earth Sun Sunlight
The discussion revolves around the phenomenon of how nearly 70% of the Earth's surface can be illuminated by sunlight simultaneously on July 8th. Participants explore the implications of this claim, questioning the mathematics and assumptions behind it, and discussing the nature of sunlight visibility on a spherical Earth.
  • Some participants question how a sphere can be illuminated beyond 50% by a single light source, suggesting that only 80% of the land area may be illuminated.
  • Others argue that nearly 70% of Earth's surface is indeed illuminated with some degree of sunlight on July 8th, citing population statistics and various sources.
  • One participant mentions that their calculations yield a figure of 69.35% of Earth's surface receiving sunlight, prompting inquiries about the methodology used to arrive at this number.
  • Concerns are raised about the accuracy of the sources cited, with some participants asserting that the claim of 70% illumination may be misreported or misunderstood.
  • There is a discussion about the role of atmospheric effects, such as diffraction and scattering, which may allow for more than 50% of the surface to be illuminated, but not necessarily by direct sunlight.
  • Some participants express confusion about the discrepancies between their calculations and the claims made in various articles, leading to further requests for clarification and sources.
Participants do not reach a consensus on the validity of the claim that 70% of the Earth's surface is illuminated. There are competing views regarding the accuracy of calculations and the interpretation of data from different sources.
Limitations include potential misunderstandings of the definitions of illumination and the effects of atmospheric conditions on sunlight visibility. The discussion also highlights the need for careful consideration of how different areas of the Earth are measured in terms of sunlight exposure.
yohananregal
How did you find PF?: Google
Hello, I am new here.
I am wondering, how is it possible for nearly 70% of the spherical Earth to be illuminated by the sun every July 8th? How can a sphere be illuminated beyond 50% with a single light source. How do we explain this?
Astronomy news on Phys.org
Welcome to PF. :smile:
Can you post a link to where you read this? Thanks.
It isn't possible. I think what you read is that 80% of the LAND AREA of the Earth is illuminated at a certain time on July 8th.
Thank you so much.
This is a known phenomenon. My friend showed it to me. Every single news outlet reported on it. I did the math, of the 99% of Earth's population who receives sunlight every July 8th, if my math is correct, it ends up being 69.35% of Earth's surface. How is this possible?
Hello, no, that is not correct. Nearly 70% of Earth's surface is illuminated with some degree of sunlight, every July 8th, UTC. That is a fact.
  • Haha
It's possible your maths is incorrect!
Hello, you are incorrect. Can you help?
yohananregal said:
Hello, yes. If you look at Time and Date's map and do the math, it is 69.35% of Earth's surface. How is this possible?
Can you tell us exactly how you're arriving at this number?
Are you by any chance measuring the percentage of the area on that map that is illuminated vs dark?
Because if you're doing that, you need to be careful which of the four progressively darker contours you're measuring against.
The first one, i.e. the brightest part of the map, is the only one showing where the Sun is visible above the horizon. This is the one that is 50%* of the total area of the map, as one would expect on an illuminated sphere without an atmosphere.
The other three show various grades of twilight - this is where the Sun is below the horizon, so it doesn't shine directly onto any part of the Earth within those contours, but its light reaches the surface through a combination of diffraction and scattering in the atmosphere. In this way a sphere covered in an atmosphere-like medium can be illuminated more than 50% at any time (this is not specific to the 8th of July, but any day of the year). If you're measuring against those, you'll get more than 50%. But, again, in this case it is not direct sunlight.
*I'm not sure the map goes into that much detail, but even the first contour should cover a little over 50%, as the aforementioned diffraction (bending of light) makes the rising/setting Sun briefly visible above the horizon even though it is geometrically below it.
glappkaeft said:
No, you are incorrect. Can you show us your source or calculations and we should be able to tell you why.
This article (an slightly expanded version of the original at www.timeanddate.com) might be where the original correct claims comes from that has since become misreported.
https://Earth'sky.org/earth/99-percent-worlds-population-receive-sunlight/
Hello, are you saying that 99% of Earth's population, which translates to nearly 70% of Earth's surface has been misreported by every major news station?
If this is true, I can not reconcile how that works. Any help?
https://www.timeanddate.com/news/astronomy/99-percent-sunlight-july-8
https://www.fox2detroit.com/news/99-of-worlds-population-under-sunlight-friday-morning
https://www.msn.com/en-in/news/tech...-time-today-check-crazy-phenomenon/ar-AAZlSkr
https://news.yahoo.com/99-worlds-population-face-sun-113829427.html
https://www.today.com/video/99-of-w...-sunlight-at-same-time-on-friday-143648325539
https://www.cnet.com/science/space/...-the-same-time-on-friday-but-there's-a-catch/
https://www.news18.com/news/buzz/99...nlight-on-july-8-heres-the-truth-5508001.html
https://www.iflscience.com/on-july-...-Earth's-population-will-be-in-sunlight-64353
Those sources do not have a 70% number anywhere.
Hello, I found the first article online.
I read time and date and several other sites. I traced the terminator lines onto a globe and the math works out. This is not what spherical trigonometry teaches in regards to the Heliocentric model. The model claims 50% illumination, including twilight zones, maybe a percentage or two more accounting for possible unpredictibly erratic atmospheric refraction.
But 19.35% more? How is this possible. This is kinda freaking me out.
No, without the twilight zones. This is explained in the post you quoted.
Hello, Yes, I am aware of this. I had to do the math myself. I am asking for verification of that. Time and Date offers what they claim to be an accurate daylight map of that day and time. When I traced out the daylight, including the twilight zones, it came to just under 70% percent. This seems impossible. I can not find much info on this. But it has been widely reported.
No, it doesn't. You clearly did not do the math. You are just making claims.
  • Skeptical
  • Sad
Before you do the math, you have to consider a few facts:
What does sunlight mean? The atmosphere reflects a portion of it so that we have light some minutes after sundown. Are your calculations based on the graphic you have shown us? In that case, your math is doomed to be wrong. There is no two-dimensional flat map of the earth. How did you measure areas? Have you taken the various possible projections into account?
You have to be careful with claims made in popular magazines. Their only purpose is to get you to read their advertisements. Facts are irrelevant.
I believe you that with the twilight zones it's 70%-ish. That's not the point. The point is, w/o the twilight zones, that map shows 50% illumination. Look:
It's the same area.
You don't get twilight zones without atmosphere. You get more than 50% from the indirect light only. It's all perfectly normal.
Before I forget the main argument:
What makes the 8th of July different from any other day? Certainly nothing related to sunlight on earth. The only possibility is the different amount of land in sunlight and related to that the different number of people on land in sunlight. Whatever it is, it necessarily has to take something more into account than the sun and a sphere.
Yes, relatively small misunderstandings, repeatedly, coming from correct facts, in each step loosing details, ending up making little sense even when most inputs are true. The percentage of the Earth that experiences a astronomical twilight is a number I won't calculate before going to bed (soon) but it could be close to his number but doesn't fit the facts presented in the OP when using standard nomenclature.
Not using standard nomenclature is the best situation where you explain your thoughts in detail since no-one can "read" your thoughts.
Hello, thank you.
I have considered all of those variables. The point remains. The math is, as far as I can tell, correct. I traced the lines onto a globe and did the math. Including all the twilight zones, I came up with 69.35% of Earth's surface to receive some degree of sunlight every July 8th. I understand my measurements could be off, even if I was off by as much as 1%, that still seems impossible. However the problem remains.
Refraction is an un-uniform, unpredictable yet necessary variable to reproduce what is claimed to be a predictable, annual event. How can this be? Weather resources such as time and date, and others definitively universally state that some approximation of: 136,350,000 million of 196,900,000 million square miles of Earth's surface, receive some degree of sunlight every July 8th. That is just under 70% of Earth's surface area.
Such light patterns, if due to refraction, certainly could not be predicted decades in advance. That would require some 38,001,700 mile sq. to be uniformly lit to some degree due to highly unpredictable variables that are also annual. I don't think you understand the question. I can not find any info on this at all, nor is anyone willing to double check my math. Why?
Then show us how.
It is not unpredictable. Also show that.
It can be done by people who knows physics and computational science.
It's the same area.
Hello, Yes that is true, but then you also get less than 12 hour days. You are not understanding the issue.
I have considered all of the variables. The point remains. My math is, as far as I can tell, correct. I traced the lines onto a globe and did the math. Including all the twilight zones, I came up with 69.35% of Earth's surface to receive some degree of sunlight every July 8th. I understand my measurements could be off, even if I was off by as much as 1%, that still seems impossible. However the problem remains.
glappkaeft said:
Then show us how.
May I ask, do you know how to calculate refraction?
You really don't won't to learn do you? Communication is the FIRST step...
Please be careful. Other posters here have been vetted for the most part, and are pretty good in the subject matter. The Mentors are watching your posts in this thread.
May I ask, what that means, to be careful? I am asking people to double check my math. Would you be willing to do that?
  • · Replies 33 ·
  • · Replies 42 ·
9K
  • · Replies 29 ·
