Hydrogen Atom Ground State Wavefunction Normalisation Solution
  • Thread starter Thread starter White Ink
    Normalisation
The discussion revolves around the normalization of the wavefunction for a hydrogen atom in its ground state, specifically the expression for the wavefunction given as Ψ(r) = C/√(4π)e^(-r/a₀). Participants are exploring the mathematical process required to normalize this wavefunction.
  • Mathematical reasoning, Assumption checking
  • One participant attempts to calculate the normalization constant C and presents their result. Others question the correctness of this calculation and suggest revisiting the integration process, particularly emphasizing the need to consider the three-dimensional nature of the wavefunction.
There is an ongoing exploration of the normalization process, with participants providing guidance on the correct integration method and discussing the implications of using spherical coordinates. Some participants acknowledge previous misunderstandings and express gratitude for the clarifications provided.
Participants are reminded to consider the appropriate volume differential in spherical coordinates and the implications of integrating over three dimensions, which introduces additional factors in the normalization integral.
White Ink
A hydrogen atom in the ground state can be described by the following wavefunction:
[tex]\Psi(r) = \frac{C}{\sqrt{4\pi}}e^{- \frac{r}{a_{0}}}[/tex]
Normalise this wavefunction.
I did this and got:
[tex]C = \sqrt{\frac{8\pi}{a_{0}}}[/tex]
I have no way of checking this, so I was wondering if anybody could tell me whether I am right or wrong.
Not quite, I don't think. Can you show us how you got that?
[tex]\int^{\infty}_{0}\left|\Psi(r)\right|^{2}dr = 1[/tex][tex]\frac{C^{2}}{4\pi}\int^{\infty}_{0}e^{\frac{-2r}{a_{0}}}dr = 1[/tex][tex]u = \frac{2r}{a_{0}}[/tex]
[tex]du = \frac{2}{a_{0}}dr[/tex]
[tex]dr = \frac{a_{0}}{2}du[/tex][tex]\frac{C^{2}}{4\pi}\frac{a_{0}}{2}\int^{\infty}_{0}e^{-u}du = 1[/tex]
Using:
[tex]\int^{\infty}_{0}x^{n}e^{-x}dx = n![/tex]
[tex]\int^{\infty}_{0}e^{-u}du = 0! = 1[/tex]
Thus:
[tex]\frac{C^{2}}{4\pi}\frac{a_{0}}{2} = 1[/tex]
[tex]C^{2} = \frac{8\pi}{a_{0}}[/tex]
Think again about the first integral. Even if the wavefunction is only dependent on r, you are still integrating over three-dimensional space. Use the appropriate volume differential for this case (spherical coordinates).
You will notice the equation will reduce to an integral in just r, but it'll have a key difference with the one you're using right now.
I know exactly what you mean (integrating in the [tex]\theta[/tex] & [tex]\phi[/tex] directions becomes equivalent to multiplying to constant in front of the integration with respect to r by [tex]2\pi^{2}[/tex], since the wavefunction is independent of those two variables). I read over the question too quickly. Thank you for your help.
In addition there will be an extra factor of r^2 in the integrand, right?
Now that one beats me. I can't see where an additional [tex]r^{2}[/tex] would come from.
dV in spherical coordinates is r^2*sin(theta)*dr*dtheta*dphi. Better look that up to make sure my use of angle names agrees with yours. And you won't get a pi^2 from the integration, do it carefully.
Ooops, I feel stupid now. I forgot about the metric coefficients and took my volume element to be [tex]dr[/tex][tex]d\theta[/tex] . At least I won't be making that mistake again. Thanks.
  • · Replies 21 ·
  • · Replies 26 ·
