Solving the Quantum Mechanics of a Hydrogen Atom
The discussion revolves around the quantum mechanics of a hydrogen atom, specifically focusing on the probability density of finding the electron in various states before measurement. Participants explore concepts related to statistical mechanics, the distinction between states and observables, and the implications of using different statistical distributions for electrons.
  • One participant questions whether the probability density of finding the electron is based on the ground state or excited states (2s, 3s, etc.), proposing a method involving the Fermi-Dirac distribution to calculate the probability density.
  • Another participant emphasizes the need to distinguish between "states" and "observables" in quantum theory, explaining that measurements pertain to observables represented by self-adjoint operators.
  • It is suggested that the state of the electron can be described by a statistical operator, and the probability of measuring an observable can be calculated using energy eigenvectors.
  • A later reply raises a question about the appropriateness of using the Boltzmann factor instead of the Fermi-Dirac distribution for a single electron, noting the fermionic nature of electrons.
  • One participant clarifies that for a single electron, the distinction between bosons and fermions is not relevant, but in many-body physics, the statistical operator incorporates the nature of the particles through field quantization.
Participants express differing views on the appropriate statistical treatment of the electron's state and whether to use the Fermi-Dirac distribution or the Boltzmann factor. The discussion remains unresolved regarding the best approach to model the probability density of the electron in the hydrogen atom.
There are limitations regarding the assumptions made about the system, particularly in relation to the treatment of degenerate states and the application of statistical distributions. The discussion does not resolve these complexities.
frustrationboltzmann
Hello, I have a little problem understanding the quantum mechanics of a hydrogen atom.
Im troubled with the following question: before i measure the state of a (simplified: without fine-, hyperfinestructure) hydrogen atom, which is the right probability density of finding the electron? is it the density of the groud state (s) or the 2s, 3s...?
my assumption is the following:
the probability of a state to be occupied is given by the fermi dirac distribution for a certain temperature. so in order to get the probability density of the location of the electron before it is measured, I multiply each (normalized) probability density with the occupation probability of every eigenstate and sum over all those products. is this right or complete nonsense?
also if its right, how would I treat degenerated quantum states. my assumption. multiply every degenerated states by the probability of the fermi dirac distribution and divide by the number of degenerated states, since I assume that they all have the same probability.
this would be a mixed state, no?
I appreciate any help!
thank you very much
First of all you have to get the concepts right. In quantum theory you have to clearly distinguish between "states" and "observables". You cannot "measure states" in the usual sense but only observables.
The state of the electron is in general described by a statistical operator, i.e., a self-adjoint positive semidefinite operator with trace 1, ##\hat{\rho}##.
Then observables are described by self-adjoint operators too. The possible outcome of measuring an observable ##O##, represented by a self-adjoint operator ##\hat{O}## are the (generalized) eigenvalues of this operator. Then for each (generalized) eigenvalue ##o## of ##\hat{O}## there exists a orthonormal set of eigenvectors ##|o,\alpha \rangle## with ##\langle o,\alpha|o',\alpha' \rangle=\delta_{oo'} \delta_{\alpha \alpha'}##. If there are eigenvalues in the continuum (which can also be the case for the parameter(s) ##\alpha##) then the Kronecker ##\delta##'s become Dirac ##\delta## distributions.
If the system is prepared in the state described by the statistical operator ##\hat{\rho}##, then the probability (distribution) for finding the value ##o## when measuring ##O## is given by
$$\sum_{\alpha} \langle o,\alpha|\hat{\rho}|\langle o,\alpha \rangle.$$
For the hydrogen atom (at rest) you can use energy eigenvectors as a complete set. To fully determine the eigenvectors you can diagonalize the compatible operators ##\hat{\vec{L}}^2## and ##\hat{L}_z## as well as the spin ##\hat{s}_z## of the electron (the usual non-relativistic approximation).
Then you get energy eigenvectors for the discrete part of the spectrum (bound states)
$$|E_n,l,m,s_z \rangle, \quad E_{n} =-\frac{13.6 \; \text{eV}}{n^2}, \quad n \in \{1,2,3,\ldots \}, \quad l \in \{0,1,2,\ldots\}, \quad m \in \{-l,-l+1,...,l-1,l \}, \quad s_z \in \{-1/2,1/2 \}.$$
and generalized eigenvectors for the continuous part (scattering states)
$$|E,l,m,s_z \rangle \quad \text{with} \quad E>0, \quad l,m,s_z \quad \text{as for the bound states}.$$
The thermal-equilibrium state is given by the stat. op.
$$\hat{\rho}=\frac{1}{Z} \exp(-\beta \hat{H}), \quad \beta=1/(k T), \quad Z=\mathrm{Tr} \exp(-\beta \hat{H}).$$
The energy eigenstates are also eigenstates of the thermal-equilibrium state of course, and you can use the basis to evaluate all probabilities with the above given rules.
The energy eigenstates are also eigenstates of the thermal-equilib state of course, and you can basis to evaluate all probabilities with the above given rules.
Thank you for this detailled answer. 1 question remains unclear. Why do I use the Boltzmann factor here and not the fermi dirac probability since electrons are fermions and its not a classical system?
Here you deal only with 1 electron, and for one particle you don't recognize whether it's a boson or a fermion.
In many-body physics the statistical operator for the grand-canonical potential is still
$$\hat{\rho}=\frac{1}{Z} \exp[-\beta (\hat{H}-\mu \hat{Q} ],$$
but this time ##\hat{H}## is the quantum-field theoretical Hamiltonian, and ##\hat{Q}## is some conserved charge (or in non-relativistic physics often the particle number).
Here the Bose or Fermi nature of the particle comes in naturally due to field quantization in terms of commutators or anticommutators, respectively.
  • · Replies 18 ·
  • · Replies 17 ·
