Hydrogen atom stripped of an electron
The discussion centers on the ionization of hydrogen molecules, specifically the transformation of H2 into H II (ionized hydrogen) when stripped of an electron. Ionization is primarily achieved through methods such as electron impact ionization or XUV radiation, as direct ionization via a DC electric field is nearly impossible due to the high voltage requirements. The H2+ molecular ion is stable, and barrier suppression ionization is highlighted as a viable technique for achieving ionization under specific conditions. The consensus indicates that very high voltages are necessary to further ionize H2+ ions.
  • Understanding of ionization processes, particularly electron impact ionization and XUV radiation.
  • Familiarity with the concept of H2+ molecular ions and their stability.
  • Knowledge of barrier suppression ionization and its application in high-intensity laser fields.
  • Basic principles of electric fields and their role in ionization energy calculations.
  • Research the principles of barrier suppression ionization and its mathematical formulations.
  • Study the second ionization energy of hydrogen and its implications for electric field strength.
  • Explore the use of ultrashort high-intensity laser pulses for ionization in gas targets.
  • Investigate the operational principles and limitations of Van de Graaff generators in ionization experiments.
Physicists, chemists, and researchers in plasma physics or astrophysics who are studying ionization processes and their applications in various fields, including space science and laser technology.
Samson4
What happens if a hydrogen molecule is stripped of an electron? Will it become 2H+ or will it become H and H+?
It becomes H II ( pronounced H 2)
ionised hydrogen is very common in nebula in outer space where the electrons have been stripped off the hydrogen atoms by intense UV light and are very easily detected optically
cheers
Dave
Thank you for clearing that up.
What electric field strength is needed to remove the final electron from the ionized hydrogen? I am assuming a high enough voltage would strip the last electron an dissociate the hydrogen gas.
You can estimate the needed strength by knowing the second ionization energy. Actually ionization by DC field is almost impossible, either you will want to use electron impact ionization or XUV radiation having enough photon energy.
The H2+ molecular ion is stable.
You mean ionization by the field alone is almost impossible? But, direct contact with a charged surface of sufficient voltage and geometry will do?
There is this strong field ionization that does rely on the field more than the photon energy to realize the ionization. Typically this is done by focusing an ultrashort high intensity laser pulse onto the gas target.
That's where the problem lies. Check out "barrier suppression ionization", and use the formula for the so-called critical field (in V/m) to estimate the needed E field strength. Upon getting the value you will realize that using DC field (such as parallel plates or cathode-anode arrangement) and assuming no collisions with free electrons are possible, , the required voltage is just too unreachable.
I found a couple papers on 'Barrier suppression ionization", most talk about short pulse lasers like you mentioned. I will read them more thoroughly through the evening.
I did want to ask if your patience hasn't run out yet. The consensus is h2+ ions require very very high voltages to ionize further. Placing the dome of a van da graaff generator in pure hydrogen, very high voltages would be achieved? Ignoring the difficulty of preventing arcing from the insulation; if the h2+ ions are practically incapable of being stripped of an electron, + charge would continue to build up on the dome?
  • · Replies 17 ·
  • · Replies 28 ·
  • · Replies 18 ·
