Calculate Transition in Hydrogen for 600nm Wavelength
The forum discussion focuses on calculating the transition in hydrogen that corresponds to a wavelength of 600nm using the Rydberg formula. The user successfully calculated the frequency (5e14 Hz) and energy (3.32e-19 J) but encountered issues when determining the principal quantum number (n) due to obtaining a negative value. The user referenced the Rydberg constant and the energy formula E(n) = (-2.178e-18 J)/n², but struggled with the calculations leading to non-integer results for n. The discussion highlights the importance of understanding energy transitions in hydrogen and the correct application of the Rydberg formula.
  • Understanding of the Rydberg formula for hydrogen transitions
  • Familiarity with the concepts of frequency and wavelength
  • Knowledge of energy quantization in atomic physics
  • Basic proficiency in algebra for solving equations
  • Study the Rydberg formula in detail, including its derivation and applications
  • Learn how to calculate energy transitions in hydrogen using the formula E(n) = (-2.178e-18 J)/n²
  • Explore the concept of quantum numbers and their significance in atomic transitions
  • Investigate the relationship between wavelength, frequency, and energy in electromagnetic radiation
Students studying atomic physics, particularly those focusing on hydrogen transitions, as well as educators teaching quantum mechanics concepts.
unf0r5ak3n
use the RYDBERG formula to suggest a possible transition that would result in the observed wavelength
Hydrogen - yellow wavelength about 600nm
I used c= lambda x frequency(V) and found (V) to equal 5e14/second
I then used energy(E) = constant(h) x V and found E to equal 3.32e-19j
Last i used En = (-2.178e-18j)/n^2 to find the transition, I did 3.32e-19j = (-2.178e-18j)/n^2 and found n^2 to equal -6.57014 and I'm stuck there because it's a negative number...
Rydberg formula contains two integers, not one.
What is Rydberg constant value?
I believe negative results infer emission rather than absorption.
That formula finds the principle energy level, not the energy emission or absorption
We haven't learned rydbergs constant yet, so I was assuming we used the one I posted
we haven'y learned that formula yet, he told us to use E(n) = (-2.178x10^-18)/n^2
ok well i did (change in energy) = E(f) - E(i)
delta(E) = 3.3e-19
E(f) = En when n=2
When n=2 E= -5.445e-19
so 3.3e-19 = -5.445e-19 - E(i)
E(i) = -8.745e-19
I then used E(i) = -2.178e-18/n2
i got n= 1.57815 which doesn't make sense, can anyone tell me what i did wrong?
  • · Replies 20 ·
