Hydrostatic Force on a Plate: Solving with Reimann Sums and Integrals
The discussion revolves around calculating the hydrostatic force on a plate using Riemann sums and integrals. The original poster presents an equation related to hydrostatic force but expresses uncertainty about incorporating a specific depth measurement into their calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss how to express depth as a function of the variable y, with suggestions on defining the coordinate system. There are questions about the correct formulation of the area and depth functions, and whether the original poster's area formula is accurate.
Participants are actively engaging in clarifying the setup of the problem, particularly regarding the coordinate system and the definitions of depth and area. Some guidance has been provided on how to express these functions, but there is still uncertainty about the correctness of the area formula and its application.
There is a focus on the placement of the coordinate system, with discussions about where y=0 should be positioned in relation to the triangle. The original poster has made adjustments to their area formula based on feedback, indicating an evolving understanding of the problem context.
redjohncorn
Find the hydrostatic force against one side of the plate by Reimann sum. Then express the force as an integral and evaluate it.
F=pg*Ad
pg do not need to be solved. they can be left like that.
F=force
p= density
g=gravity
a= area
d= distance
so far i have the equation
in the attachment. However, I do not know where to put the 1 ft that lies above the triangle.
i have the area as (4/3)(3-y)
That one foot needs to be depth as a function of y. For instance, if you put the top of the triangle as y=0, increasing positively downward, then d(y) = (y+1), because at y=0, the depth will then be 1, as expected. At y=3, the depth will be 4, and so on.
You are really computing the volume of water above a particular area (more specifically, the force it causes), as a function of depth more or less. To solve these problems you can always think "How can I express depth/length/etc as a function of my independent variable"?
You are really computing the volume of water above a particular area, as a function of depth more or less.
would this integral be correct? i can never understand the whole concept about which way y is
Where are you calling zero? Can you label your axis.
Just think of it like this:
[tex]F_{H} = δ \int_{a}^{b}L(x) D(x) dx[/tex]
y= 0 starts at the very bottom of the triangle for this integral.
Okay, so you have (4-y) for your D(y), when y = 1, is the depth at that point 3? Can you test the length function L(y) in the same manner against the diagram?
if by L(x) you are talking about the area that needs to be integrated, then the area is (4/3)(3-y) since y is that unknown length above the dy section.
Yes, the area. L(y) dy is the area of the strip/rectangle. Using your axis, where y=0 is at the bottom of the triangle. When y increases (going closer to the surface), does your function 4/3(3-y) represent the length of the strip at that point? When y = 0, that L(y) function evaluates to 4/3(3-0) = 4, does that sound right to you?
no. it doesn't sound right.
ok i changed the area formula to A(y)= (4/3)y
now i think it's correct. thank you
That sounds right!
Usually, an easier way to do these problems is to put y=0 at the surface of the water, that way your depth function D(x) is just x. Then you simply need to find a way to get out the Length at some particular x value. This can greatly simplify your integrals in most cases that I have seen. If the object is circular, putting the y=0 at the center of the circle can do the same thing.
12K
14K
