Hydrostatic force on submerged curved surface
The discussion revolves around calculating the hydrostatic force on a submerged curved surface, specifically focusing on the volume calculation needed to determine the weight of the fluid. A user questions the formula presented in their homework solution, which is R^2 - π(R^2)/4, and expresses confusion about its validity as a volume calculation. Other participants clarify that the formula appears to represent an area rather than a volume, suggesting a misunderstanding in the problem statement. The conversation highlights the importance of correctly identifying formulas and their applications in fluid mechanics problems. Accurate comprehension of these calculations is essential for solving related homework effectively.
febbie22
Hi i know how to do these problems but its calculating the weight of the fluid, which you have to do to minus it from the vertical force.
But in the solutions to the problem is say that the volume is R^2 - Pie *(R^2)/4 *1
The only thing i want to know is why is that the volume because I've never seen anything like it and if it is correct is it in all the problems so i can just remeber it.
Cheers
Hi febbie22! :smile:
(have a pi: π and try using the X2 tag just above the Reply box :wink:)
Can you give us more detail about this problem?
(and there's no way that R2 - πR2/4 can be a volume … it's obviously an area :confused:)
Hi its question 11-19, i triedto put it on word but it didnt let me upload. And I've got the solutions to the problem. and so when it says to calculate the weight it says
rowg * (R^2 - Pie * (R^2)/4 * 1
(please use the X2 tag just above the Reply box :wink:)
I can't find that formula … which page is it on? :confused:
(and it's spelt rho, and you must have missed out an h … that's still an area!)
oh sorry it example 11-2 on page 494
and its the weight of fluid block per m length
that i don't get
that i don't get
I can't see a page 494 …
have you posted the correct document? :confused:
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 16 ·
