I am an idiot. I can't even do this properly
  • Thread starter Thread starter flyingpig
    even
The problem involves determining a point on the graph of a transformed function given a specific point on the original function. The original poster is confused about the behavior of the y-value during the transformation.
  • Participants discuss the implications of the transformation on the y-value, questioning why it remains constant despite the transformation. They explore the relationship between the original point and the transformed function.
There is an ongoing exploration of the transformation's effects, with some participants providing insights into the nature of horizontal versus vertical transformations. Multiple interpretations of the transformation's impact on the y-coordinate are being considered.
Participants are working under the assumption that they only know the point (6, -12) on the graph of y = f(x) and are trying to understand how this relates to the transformed function without additional information about f(x).
flyingpig
If the point (6, -12) is on the graph of y = f(x), which point must be on the graph of y = f(-x/3 + 6)?
M/C
a) (-36,-12)
b) (-24, -12)
c) (0, -12)
d) (16,-12)
First of all, I am a little confused why doesn't the y value change? Why is it staying as y = -12? Doesn't f(x) change?
Also I tried doing f(-6/3 + 6) = f(-2 + 6) = f(4) = ?
Yeah...
Okay okay okay, let's try this algorithm, and then someone explain to me why this works
-x/3 + 6 = 6
-x/3 = 0
x = 0
You only know one y value: namely, you know that f(6) = -12.
In the case of f((-x/3 + 6) , what must x be in order for you to have f(6) ?
0...but why does y change?
y doesn't change.
You still have y = f(6) , which is -12.
But isn't f(-x/3 + 6) a transformation ?
The answer is (0,-12). All you really know here is that (6,-12) lies on y=f(x), but you do not know what is f(-x/3+6)=?. So you can only use the given info. And I think the explanation given by SammyS is the best way to do this.
Yes, it is a transformation, but only in the x direction (scale and translate horizontally).
To transform in the y direction you would need for instance:
y = f(x) / 3 + 6.
Or to do both:
y = f(-x/3 + 6) / 3 + 6.
No, let y = f(x) = -2x
Clearly f(6) = -12, which gives us (-6,12)
Now for a transformation f(-x/3 + 6)
f(-x/3 + 6) = -x/3 + 6, this clearly changes the y-valuse.
You probably meant (6, -12), although (-6, 12) is also on the graph of this line.
Assuming that f(x) = -2x, then f(-x/3 + 6) = -2(-x/3 + 6) = 2x/3 - 12
You've chosen an example where you can't really distinguish between the two.
This is a line with a slope, so any horizontal transformation can also be expressed as a vertical transformation, which is basically what you've shown.
Yeah so if you do f(-6/3 + 6) = -8
But it's still generalizing that f(-x/3 + 6) has no effect on the vertical component.
I don't quite understand what you're saying here...
But I'll put it like this:
flyingpig said:
Let y = f(x) = -2x
Clearly f(6) = -12, which gives us (6,-12)
So f(6) = f(-0/3 + 6) = -12
The horizontal transformation is that x=0 is sent to f(-0/3 + 6)=f(6)=-12, which gives us (0, -12).
No change in y coordinate, but the x coordinate of 6 has been transformed to x=0.
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 20 ·
