I don't believe that an area/volume can change based on a change in shape
  • Context: High School
  • Thread starter Thread starter Femme_physics
    Change Shape
This discussion centers on the relationship between shape, area, and volume, emphasizing that altering the shape of an object can change its surface area while keeping its volume constant. Participants provided examples, such as a ball of clay being flattened or water spilling from a glass, to illustrate how surface area can increase without a change in volume. The conversation also touched on the misconception of "conservation of area" and "conservation of volume," clarifying that these laws do not exist. Ultimately, the discussion concluded that while volume can remain constant, surface area can vary significantly based on shape alterations.
  • Understanding of basic geometric concepts
  • Familiarity with surface area and volume definitions
  • Knowledge of the properties of shapes, such as circles and rectangles
  • Basic principles of dimensional analysis
  • Research the mathematical formulas for calculating surface area and volume of various shapes
  • Explore the concept of convex and concave shapes in geometry
  • Investigate real-world applications of surface area and volume in engineering and design
  • Learn about the implications of shape changes in materials science, such as in the behavior of liquids and solids
Students, educators, and professionals in mathematics, physics, and engineering who seek to understand the dynamics of shape, area, and volume relationships.
Femme_physics
And I know that I'm being extremely stupid in saying that.
I know I'm mathematically wrong.
Please convince me otherwise.
It doesn't make sense to me that if I change the shape of something it can alter its area/volume. I always thought these remain constant. Is there any experiment that I can see that will make me see the proof of it? Or a convincing argument without math, at least?
Seeing it mathematically is one thing, seeing it in reality is another.
What do you mean by 'something'? What are you keeping constant?
For a trivial example of how keeping the same volume but changing the shape can alter surface area: Imagine a ball of clay. Squash it into a flat pancake shape. By squashing it flat enough, you can make the surface area as much as you like.
You can do the same thing with a glass of water. In the glass, the water has some surface area. Spill it on the floor and the surface area is much more.
Any certain shape to another shape
Ah, so the area is being lost to volume, and vice versa, yes? So we can say that these two have an inverse relationship?
Also, is a perfect ball the best shape for max volume?
Okay, I can understand "volume" and "area" relationship, but let's say I have a fence...how can I just by changing the way the fence is defined around the perimeter change the area. When it comes to area and volume, we can say that lost volume goes to area, and lost area goes to volume. Is there an inverse relationship in the fence example as well?
With fences, the length of the fence never changes, there's no volume in 2D, and yet somehow-- as though magically, the area size does!
no volume is being lost. Surface area is being gained. In some geometric shapes you may say the effective thickness is being lost (like a cube gets flatter and flatter, losing thickness, gaining surface area)
You can also break things apart, like a snowball, and it now has more surface area, but same volume. I always kick snow all over during melt down to help the sun melt it faster by increasing the surface area [/nerd]
That's too vague to be useful. Change a cube the size of your house to a sphere the size of a pea. Both volume and surface area have changed. So what? (In changing from one to the other something must be kept fixed.)
No. As Pythagorean has pointed out, the volume remains fixed in those examples.
For a given surface area, yes.
I don't quite get what you're saying. In your fence example, the perimeter of the shape remains fixed (it equals the length of the fence). You can arrange the fence in a circle, a square, a thin rectangle; all have different areas, but the same perimeter.
Make a rectangle from four sticks, held together by pins so the sticks can pivot on the pins.
When the angles are right angles, so the figure is a rectangle, the area is largest. Now, warp the figure, pivoting on the pins, you can make the area smaller and smaller until, eventually, the area goes to 0.
You seem to believe there is some law of "conservation of area" or "conservation of volume" and that simply is not true.
Good point.
Good Samaritan :)
It actually makes sense to me now that you explain how to get to area 0. I guess I can see now that such "law of conversation of area/volume" do not exist. It's just not intuitive to me. Or wasn't. I appreciate relating this to me :)
Thanks everyone, appreciate the feedback!
Please note that this is not always true.
It is possible to reduce (or increase) the volume, whilst maintaing a constant surface area.
You can do this by exchanging a convex region of surface for a concave one and vice versa.
A simple example is a table tennis ball.
The whole surface is convex.
Press in a dimple with your finger, exactly the reverse to what was there before.
Voila (that's French)
Your ping pong ball now has the same surface area, but less volume.
go well
Here's another one.
When you crumple or flatten a milk carton or a coca cola can, the area remains the same, but the volume decreases. :smile:
Oh, I like that! Much more violent than my example!
  • · Replies 22 ·
  • · Replies 33 ·
