Undergrad I don't get the Slowly Varying Envelope Approximation
  • Thread starter Thread starter carllacan
    Approximation
The Slowly Varying Envelope Approximation (SVEA) is mathematically defined by the inequality $$ \left \vert \frac{\partial ^2 E_0}{\partial t ^2} \right \vert << \left \vert \omega\frac{\partial E_0}{\partial t}\right \vert $$, indicating that the second derivative of the envelope function, $$E_0$$, is negligible compared to its first derivative. This approximation holds true when the envelope varies slowly and is nearly linear over time, particularly in regions where the function does not bend steeply. Understanding SVEA requires recognizing that the sinusoidal oscillation is excluded from the envelope's behavior, allowing for a clearer interpretation of the mathematical expression.
  • Understanding of calculus, specifically derivatives
  • Familiarity with sinusoidal functions and their properties
  • Basic knowledge of mathematical inequalities
  • Concept of linearity in mathematical functions
  • Study the implications of the Slowly Varying Envelope Approximation in wave mechanics
  • Explore the mathematical derivation of the SVEA in electromagnetic theory
  • Learn about the role of higher-order derivatives in approximations
  • Investigate applications of SVEA in optics and signal processing
Students and professionals in physics, particularly those focusing on wave theory, electromagnetism, and signal processing, will benefit from this discussion on SVEA.
carllacan
Hi.
I can't for the life of me understand the math behind the SVEA. I graphically/intuitively understand what it means that the envelope varies slowly, but I can't connect that with the mathematical expression: $$ \left \vert \frac{\partial ^2 E_0}{\partial t ^2} \right \vert << \left \vert \omega\frac{\partial E_0}{\partial t}\right \vert $$
If the field is sinusoidal then the first derivative should simply add a factor of ω , so that $$ \left \vert \frac{\partial ^2 E_0}{\partial t ^2} \right \vert = \left \vert \omega\frac{\partial E_0}{\partial t}\right \vert $$
but instead the approximation says that <<. What am I missing?
THank you for your time.
SVEA means that the envelope is almost linear everywhere with very minimal bends. That's how you come with
If the above inequality holds, you don't need to worry about the higher order derivatives, they are guaranteed to be much smaller than the first derivative.
You can imagine a function which increases monotonically and is very close to being linear for ##t<0##. In ##t>0##, it's also very close to linear but keeps decreasing. In these two regions, the above equality can be seen to hold with a high degree of validity. But at the turning point ##t=0##, the function may bends downwards too steeply such that the second derivative cannot be neglected at this point. To avoid this, the transition must be occurring with a somehow very long duration of time such that everywhere the function's second derivative is negligible. Just imagining this picture in mind should lead you to conclude that this function must vary slowly.
##E_0## is the envelope, the sinusoidal oscillation is already excluded.
Likes carllacan
##E-0## is the envelope, the sinusoidal oscillation is already excluded.
All clear now, thanks!
In sci-fi when an author is talking about space travellers or describing the movement of galaxies they will say something like “movement in space only means anything in relation to another object”. Examples of this would be, a space ship moving away from earth at 100 km/s, or 2 galaxies moving towards each other at one light year per century. I think it would make it easier to describe movement in space if we had three axis that we all agree on and we used 0 km/s relative to the speed of...
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 0 ·
