I don't understand Dedekind cuts
  • Level: Undergrad
  • Thread starter Warp
14 replies · 3K views · last reply
Warp
I have now tried for an hour to make ChatGPT make me understand how this works, without success, so I humbly ask for a clearer explanation.
The succinct way to express what I don't understand is this:
A "Dedekind cut" simply splits the set of numbers into two, without dropping any values and retaining ordering, so that every value on the left of the cut is less than every value on the right of the cut. Let's apply this to the set of rational numbers:
  1. Every rational number splits the set of rationals into two subsets, and this split is unique.
  2. Every irrational number splits the set of rationals into two subsets, and this split is unique.
(In this context "unique" means that two different numbers used to do the split never produce the same subsets of the rationals. Every unique number produces a unique split, no duplicates.)
This makes it sound like the set of rationals and the set of irrationals are of the same size. Yet, somehow, there are (uncountably many) "more" of the second type of cuts than the first type. How can a countably infinite set have uncountably many unique splits of this kind? It defies intuition and logic.
I don't see, why ^^^^.
You could add, e.g.,
3. Number 5 splits the set of rationals into two subsets, and this split is unique.
Does it make it sound like the set of rationals and the set 'number 5' are of the same size?
You may be misunderstanding unique in this context. It doesn't mean that you can not produce the same subsets in different ways. What it means is that if two different ways of producing a split lead to the same split, then those two ways are a representation of the same number, the smallest number in the upper cut.
So, for an almost trivial example for the lower cuts $$A=\{a \in \mathbb{Q}:2 a<1\}$$ and $$A'=\{a \in \mathbb{Q}:6 a<3\}$$ Since ##A=A'## the numbers defined are the same number. The cut for ##A## is the rational number ##1/2## and the cut for ##A'## is the rational number ##3/6##. The fact that ##A'## is a duplicate of ##A## means that ##1/2## and ##3/6## are the same unique number.
You compare the sizes of sets by finding a one-to-one mapping between the sets. If there is such a mapping, then the sets are the same size. In the Dedekind cuts, the number identified by the cut is the smallest element of the upper cut. So, consider the lower cuts $$A=\{a \in \mathbb{Q}: a^2<2 \cup a<0\}$$ and $$A'=\{a \in \mathbb{R}: a^2<2 \cup a<0\}$$There is a least element in the upper cut for ##A'##, but the upper cut for ##A## has no least element. So this cut does not place the reals and the rationals in a one-to-one mapping. There exist elements in the reals that do not map to elements in the rationals through cuts.
This mapping maps every number in the rationals to a number in the reals, but not every number in the reals to a number in the rationals. So it is not one-to-one, and there are more elements in the reals by this mapping. By itself this is not a conclusive proof that the cardinality of the reals is larger than the cardinality of the rationals since you have to prove the non-existence of a different one-to-one mapping. But certainly this mapping is not one-to-one so it does give credence to the idea that the reals may be bigger than the rationals.
Dale said:
There is a least element in the upper cut for A′, but the upper cut for A has no least element. So this cut does not place the reals and the rationals in a one-to-one mapping. There exist elements in the reals that do not map to elements in the rationals through cuts.
I was not talking about the set of real numbers but about the set of irrational numbers, both in the description of the problem and my sentence "this makes it sound like the set of rationals and the set of irrationals are of the same size."
If the argument is "since there is no 'smallest rational number that's greater than the irrational number used for the split', then the set of irrationals is larger", the same argument could well be used in the reverse:
"Since there is no 'smallest irrational number that's greater than the rational number used for the split', then the set if rational numbers is larger."
As mentioned at the end of my original post, my confusion can be summarized as:
"How can a countably infinite set have an uncountable amount of unique Dedekind cuts?"
It sounds like cutting the set of rationals into more parts than there are rationals, which completely defies intuition.
Talking a bit more with ChatGPT about this subject, I think I got a sort of understanding breakthrough, after understanding two key facts:
  1. Using two Dedekind cuts on the set of rational numbers is, essentially, selecting a subset of the rational numbers (between the two cuts).
  2. There are uncountably many subsets of the rational numbers.
(Fact 2 might not be immediately obvious, but I'm assuming it's for a similar reason why the set of all possible infinite strings is uncountable.)
In other words, we are not really mapping unique cuts to unique rational numbers. Instead, we are essentially counting how many possible subsets of the rationals there are.
Please remember that AI is not allowed as a reference in the technical PF forums. You haven't posted your AI discussion here in this thread, so you are okay for now, but I just wanted to remind you in case you were tempted. :smile:
Oops, that is true.
I don’t think that Dedekind cuts can constitute any sort of mapping between the rationals and the irrationals. A Dedekind cut at an irrational does not map to any rational numbers.
That is not a valid argument about the size of the two sets. The only way to make that kind of argument is to make a mapping between rationals and irrationals. The Dedekind cut approach does not do that.
Yes. Every rational corresponds to a Dedekind cut of the rationals. But not all Dedekind cuts of the rationals correspond to a rational.
A Dedekind cut of the rationals with a smallest element of the upper cut corresponds to that rational. But there are Dedekind cuts of the rationals with no smallest element of the upper cut. So indeed there are more cuts than there are rationals: every rational can be mapped to a cut, but not every cut can be mapped to a rational.
That makes it sound that there would be duplicates. In other words, two different irrational numbers would generate the same split of the set of rationals (and, in fact, for there to be uncountably many cuts, infinitely many irrationals would give the same split of the rationals.)
However, as far as I understand, no two different irrationals will ever split the rationals the same way. In other words, every split is unique.
For any two distinct irrational numbers consider the decimal expansion of the numbers to the first digit where they differ. The larger of those two decimal expansions is a rational number that is larger than one irrational and smaller than the other irrational. So it will be in the upper cut for one and in the lower cut for the other. Thus, two different irrationals do not generate the same split.
Re: post #5. Here is the usual proof that every set has more subsets than elements.
If S is any set (e.g. the set of rational numbers) and 2^S is the set of its subsets, and if S had as many elements as subsets, then there would be a surjective map f:S-->>2^S. We claim this is impossible, i.e. given any map f:S-->2^S, we will construct a subset of S that cannot be in the image of f. Namely take T to be the subset of those elements x of S such that x is not an element of f(x). If T were in the image of f, then there would be an element y of S such that f(y) = T. Since T = f(y), by definition of T, y belongs to T if and only if y does not belong to f(y) = T. Hence such an element y does not exist, so f is not surjective. In particular there is no surjection from the set of rationals to the set of subsets of rationals.
I find it still somewhat interesting, as you did, Warp, that there are more of the special subsets forming cuts than there are rationals; especially since those cut subsets having a boundary point are only countable, and it is only those with no boundary point that are larger. As Dale observes, a cut with a rational boundary point clearly corresponds to that rational point, but it is not so clear to me why those without a boundary point are more numerous. The only way I can think of is to associate such a cut to an infinite decimal and use the usual proof that there are uncountably many such decimals. I.e. intuitively, any attempt to associate a boundary point where there is none, would require an infinite sequence of approximate boundary points. Then we are in the situation of having more infinite sequences of rationals, than single rationals. I find this is a nice, very observant, question, and one that certainly had not occurred to me before.
Yeah, even with the additional insight in that post #5, I'm still having a hard time understanding why there are more Dedekind cuts of the rationals using irrationals than there are using rationals, given that the cuts using irrationals are still unique and do not cause duplicates.
If you have a finite set of numbers, it will have that many unique cuts, no matter what numbers you use for the cuts (assuming the condition that only numbers that do not cause duplicate cuts can be used). Likewise if you cut the set of integers into unique cuts, you get as many cuts as there are integers.
Yet, when using the set of rationals, we get a different behavior: If you cut it using rational numbers, you get countably many cuts, but if you cut it using irrational numbers, you get uncountably many cuts, even though every cut is still unique?
Of course the difference between the set of rationals and the set of integers is that the former is "dense", and that is, apparently, the crucial difference. Still, I do not know enough about the subject to understand why it makes a difference.
Another insight:
When using rational numbers to make the Dedekind cut, there are only countably many ways to choose said rational number.
When using irrational numbers to make the Dedekind cut, there are uncountably many ways to choose said irrational number.
So, in a sense, when you are using rational numbers to cut the set, you are, in a way, "limiting yourself" to only choosing cut points from a countable set. With irrationals you are removing that limit. Because the set of rationals is dense, it allows for uncountably many unique cut points, even though the set itself is countable.
In other words, the "support" for uncountably many unique cuts is already there in the set of rational numbers, and if I choose rationals to do the cuts I'm limiting the cuts to a countable amount. (So, in a way, I was originally thinking of the problem in the wrong direction. The Dedekind cuts using irrationals are not somehow "adding more cut points to the set". Instead, it's the other way around: Cuts using rationals are restricting the cut points to a countable amount.)
I wonder if I'm getting a bit closer to the true explanation.
Yeah, infinite sets are weird. Intuition can really lead you wrong.
The main difference is this: with non-dense sets you cannot even make Dedekind cuts. There is no way to make the lower cut have no greatest element. Any division that you make into upper and lower sets, the upper cut will have a least element and the lower cut will have a greatest element.
What even are irrational numbers if the first order of business is to establish the set of all Dedekind cuts?
The irrational numbers are the Dedekind cuts of the rationals where the upper cut has no least element.
