I think of it as hard proof by induction
The discussion focuses on proving mathematical statements related to the sequence defined by a recurrence relation: a_{n+1}=(a_n+\frac{1}{a_n})^{\lambda} with a_1=1 and λ>1. Participants emphasize using mathematical induction to establish that a_n ≥ 2^{g(n)} where g(n)=λ^{n-1} for n ≥ 2, and to show that a_{n+1}/a_n > 2^{(\lambda -1)g(n)}. The proof involves demonstrating the base case for n=2 and applying the inductive hypothesis to derive the necessary inequalities.
  • Understanding of mathematical induction
  • Familiarity with sequences and recurrence relations
  • Knowledge of logarithmic properties and inequalities
  • Basic algebraic manipulation skills
  • Study the principles of mathematical induction in depth
  • Explore advanced topics in sequences and series
  • Learn about inequalities and their applications in proofs
  • Investigate the properties of exponential functions and logarithms
Students and educators in mathematics, particularly those focusing on proof techniques, sequences, and mathematical induction. This discussion is beneficial for anyone looking to strengthen their understanding of these concepts.
rock.freak667
[SOLVED] I think of it as hard proof by induction
given for the sequence a_1,a_2,a_3,a_4,...,a_1=1 and that
where\lambda>1.Prove by mathematical induction that,for n \geq 2
a_n \geq 2^{g(n)}
where g(n)=\lambda^{n-1}
Prove also,for n \geq 2
\frac{a_{n+1}}{a_n}>2^{(\lambda -1)g(n)}
well what I tried to do was to consider a_{n+1}-2^{g(n)}
which after simplification gives:
\frac{(a_n^2+1)^{\lambda}}{a_n^{\lambda}}-2^{g(n)}[/itex]<br /> <br /> which I then said should be greater than or equal to zero since the fraction on the left is +ve and 2^g(n) is positive since lambda is &gt;1. Is this a good way to start?
Not really. I think you are supposed to use induction. Prove the statement is true for n=1. Then prove is the statement is true for n, then it's true for n+1. Isn't that how induction is supposed to go? What you've done so far doesn't look very 'inductive'.
Well what I was essentially trying to do was to find an expression for a_n+1-2^g(n) and then add,subtract,multiply and divide various things to a_n \geq 2^{g(n)} and then eventually say that from my expression a_n+1 >= 2^g(n)
Yeah, I know. But the problem says 'use induction'. And that might be the best way to go. I'll warn you, I haven't actually tried to do it.
As Dick mentioned induction may be the way to go:
a_2=2^{\lambda}
Take your expression now and show that the statement is true for n=2 (I guess this is also your inductive hypothesis):
<br /> \frac{(a_n^2+1)^{\lambda}}{a_n^{\lambda}}-2^{g(n)} \geq 0 --&gt; \frac{(a_n^2+1)}{a_n} \geq 2^{\lambda^{n-2}}<br />
So then:
\frac{(a_2^2+1)}{a_2} \geq 2 --&gt; \frac{(2^{2\lambda}+1)}{2^{\lambda}} \geq 2
So now you need to find a way to express the relation for n=k+1. I guess expanding a couple of terms may be helpful, but I always came back to the general form that you proposed.
Then just say:
Assume true for n=N
a_N \geq 2^{g(n)}
+ \frac{1}{a_N}
a_N +\frac{1}{a_N} \geq 2^{g(n)} +\frac{1}{a_N}
Raise both sides to the power of \lambda
(a_N +\frac{1}{a_N})^{\lambda} \geq (2^{g(n)} +\frac{1}{a_N})^{\lambda}
and then say that
(2^{g(n)} +\frac{1}{a_N})^{\lambda} \geq 2^{g(N+1)}
and so
a_{N+1}&gt;2^{g(N+1)}
and hence true by PMI ?
We need to show that
(an + 1/an)^t >= 2^(t^(n))
Observation:
t*ln(an + 1/an) >=t^(n)ln(2)
ln(an + 1/an) >= t^(n-1)(ln(2))
an + 1/an >= 2^(t^(n-1))
Since t >= 1, it's an increasing sequence. Thus,
an + 1/an > an >= 2^(t^(n-1)) by the inductive hypothesis. QED.
I see no problems with your proof.
Observation:
hm.didn't think about taking ln...interesting
But I might need to justify why
so I would just say that the 2^g(n)+(anything) must be bigger than 2^(g(n+1)) since a_n is greater than zero
(2^(t^(n-1) + 1/an)^t >= 2^(t^(n-1)*t) = 2^(t^n) = 2^(g(n+1)). The inequality holds since t> 1 and an is positive.
  • · Replies 51 ·
