I trying to find mass with these varbiales.
  • Thread starter Thread starter Sadriam
    Mass
To find the mass of a roller coaster train using the provided data, one needs to consider the initial and final speeds, vertical and lateral forces, and the effects of friction. The discussion highlights that without knowing the magnitude of friction, deriving mass from the given information is not feasible, as mass does not influence the trajectory of the object. Energetic considerations may help estimate friction, which is crucial for calculating mass. Clarification on the data, particularly the direction of speed and the specifics of the forces involved, is essential for accurate calculations. Ultimately, obtaining the friction value is key to determining the mass of the roller coaster train.
Sadriam
Im trying to find the mass of an object. It is not a problem, but i would like to find it so that i could use the mass for other calculations. I have the object's:
speed / velocity from one point to another.
The initial and final height of the object.
The vertical and horizontal forces on it. (labled as vert g's and hor g's)
Gravity (9.8)
I don't even know if it is possible with the given information, but if it is i would be really happy. If you suspect that i may have another variable available, you can ask, and i can see what i can do.
Thanks.
When you say that you know the "speed/velocity from one point to another" you mean that you have the vector function v(t) or just intial and final speed?
How many forces, you say, are working? I mean, is that data from a free falling object or there are more forces implied?
It'd be great for everybody if you are a little bit more precise we'll be glad to help you :)
Now, considering a falling object and not taking into acount the air friction, you won't certainly be able to derivate the body's mass from that particular data. You may think that, as the data only referes to the cinematics of the object, every one that made that trajectory (whatever its mass) will do the same; so mass is not a distintive parameter of the process.
But as I said above you should clarify what you excatly meant :)
good nicght and good science.
OK sorry about the wait. Actually this is a train on a roller coaster. When i say i have speed/velocity, i do not have the direction so technically i don't have the velocity, but i don't think this would matter much. I can get the initial and final speed from one point to another.
The forces that the simulator tells me are Vertical G's, Lateral G's, and Acceleration G of the train on the track.
Friction of the track and the train is also in there, because the train will not make it to its initial height, so some energy is loss from friction. I also do not know how much friction is there either, so that is unfortunate.
If this is possible, please help.
Ok, so it's a roller coaster.
Then still the same than the free falling if you don't know the magnitude of friction.
You may calculate it by making energetic consideration with the data you gave me.
Try, & if you can tell me bacause if you get the amount of friction then you'll be able to get the mass.
Salutations. Zap
I am going through this course on collision detection: https://siggraphcontact.github.io/ In this link is a PDF called course notes. Scrolling down to section 1.3, called constraints. In this section it is said that we can write bilateral constraints as ##\phi(\mathbf{x}) = 0## and unilateral constraints as ##\phi(\mathbf{x}) \ge 0##. I understand that, but then it says that these constraints call also be written as: $$\mathbf{J} \mathbf{u} = 0, \mathbf{J} \mathbf{u} \ge 0,$$ where...
