I with hw (my book hasnt came in yet)
  • Thread starter Thread starter JJ89
    Book
11 replies · 6K views
JJ89
1.A mass m = 20 kg is moving along a surface with coefficient of kinetic friction mk = 0.3.
A)What is the force of kinetic friction on the mass?
2.A wooden block of mass m = 9 kg starts from rest on an inclined plane sloped at an angle q from the horizontal. The block is originally located 5m from the bottom of the plane.
a)If the block, undergoing constant acceleration down the ramp, slides to the bottom in t = 2 s, and q = 30°, what is the magnitude of the kinetic frictional force on the block?
3A block of mass m1 = 2 kg and a block of mass m2 = 3 kg are tied together and are pulled from rest across the floor by a force of Fp = 21 N. The coefficient of friction of the blocks with the floor is µ = 0.13.
a) What is the acceleration of the two blocks?
a = ?m/s2
b) What is the tension in the string between the blocks?
T = N ?
4 A block of mass mblock = 1.9 kg rests on a cart of mass mcart = 3.1 kg, which moves without friction on a horizontal surface. The coefficient of static friction between the block and the cart is µ = 0.76. The cart is accelerating to the right.
a) What is the maximum acceleration such that the block does not slide on the cart?
amax = ? m/s2
b) What is the magnitude of the force on the cart required to provide the acceleration amax?
F = N ?
Well show what you have going, don't know where to help.
this is for #3
So how far are you on that nr. 3? The golden rule of all homework forums, no-one is going to solve the problem for you.
Hint: write out Newtons second law for every body involved.
Oh alright I am on B, the acceleration is 2.94 and i can't find the tension in between.
So you mean you are on exercise 3). For these kind of tension problems there are two powerful tools:
a) Make a good drawing of the setup, put all the forces on the diagram and also add a coordinate axis (in pulley problems you simply bend the axis around the pulley). The axis will give you a clear view on the signs of things.
b) Write out Newtons second law for every body included, then solve the equation system you get.
