I would like some assistance working with commutators
  • Context: Undergrad
  • Thread starter Thread starter hmparticle9
This discussion focuses on the manipulation of commutators in quantum mechanics, specifically involving angular momentum operators defined as ##\mathbf{L} = \mathbf{r} \times \mathbf{p}##. The user seeks clarification on the application of canonical commutation relations, particularly in the context of terms dropping out during calculations. The discussion confirms that terms like ##[y p_z, x p_z]## yield zero due to the commutation properties of the involved variables, and emphasizes the importance of correctly applying these relations to simplify expressions.
  • Understanding of angular momentum operators in quantum mechanics
  • Familiarity with canonical commutation relations
  • Proficiency in manipulating algebraic expressions involving operators
  • Knowledge of quantum mechanics terminology and notation
  • Study the properties of angular momentum operators in quantum mechanics
  • Learn advanced applications of canonical commutation relations
  • Explore examples of commutator calculations in quantum mechanics
  • Review operator algebra techniques in quantum mechanics
Students and professionals in physics, particularly those specializing in quantum mechanics, as well as educators looking to clarify the manipulation of commutators and angular momentum operators.
hmparticle9
I am starting to realise that I am struggling with commutators, and I want to address this before moving on. This particular example involves the angular momentum ##\mathbf{L} = \mathbf{r} \times \mathbf{p} ##.
$$[L_x, L_y] = [y p_z - z p_y, z p_x - x p_z] = [y p_z, z p_x] - [y p_z, x p_z] - [z p_y, z p_x] + [z p_y, x p_z]$$
This is an application (twice) of ##[A+B, C] = [A,C] + [B,C]##. Good so far.
My book says the following: "from the canonical commutation relations the two middle terms drop out". If I expand the two middle terms and apply the canonical commutation relations a few times to "shift" things about. For instance:
$$[y p_z, x p_z] = y p_z x p_z - x p_z y p_z = yx p_z p_z - xy p_z p_z = 0$$
Then (only then) can I say that the middle terms drop out. But seeing that they drop out directly from the canonical commutation relations, I can't see it. So that is my first problem. I might be reading into things a bit too much, and the author might mean that I need to use the canonical commutation relations a few times for things to drop out.
My second issue is that it is stated that
$$ [y p _z, z p_x] = y p_x [p_z, z], \text {and } [z p_y, x p_z] = x p_y [z, p_z] $$
Again, repeated use of canonical commutation relations we can say
$$[z p_y, x p_z] = zp_y x p_z - x p_z z p_y = p_y x(zp_z - p_z z) = x p_y [z, p_z]$$
I just want to make sure I am following things correctly, and that I'm not missing a trick
hmparticle9 said:
For instance:
Your method is fine. To shortcut it, you can note that all factors in ##[y p_z, x p_z]## commute among themselves. Thus, ##x## commutes with ##y## and ##p_z## , ##y## commutes with ##x## and ##p_z## , and ##p_z## commutes with itself and ##x## and ##y##. So, the result of the commutator is zero.
Good.
Since ##x## commutes with ##z## , ##p_y## , and ##p_z## , ##x## can treated as a factor that can be pulled out of the commutation. Likewise ##p_y## commutes with ##x##, ##z##, and ##p_z##. So, ##p_y## can be pulled out. It doesn't matter whether you "factor out" the ##x## to the left side or the right side. Same for ##p_y##. And it doesn't matter the order in which you pull out the ##x## and ##p_y##. Thus, you can go immediately from ##[z p_y, x p_z]## to ##x p_y [z, p_z]##. Be sure to respect the order of ##z## and ##p_z##.
While getting familiar with this sort of manipulation, if you have any doubt it's a good idea to write things out as you have done.
  • · Replies 24 ·
  • · Replies 39 ·
  • · Replies 17 ·
