Idea for optimising solar collection
  • Context: Graduate
  • Thread starter Thread starter RandomRed
    Idea Solar
The discussion revolves around the optimization of solar collection using a proposed design that incorporates flat panel magnifying lenses, fiber optics, and spectral separation of light. Participants explore the feasibility of this idea, its potential benefits, and alternative approaches to solar energy collection.
  • One participant suggests using cheap flat panel magnifying lenses on a hinge to track the sun, focusing light onto fiber optics that would then split the light into its spectrum for testing different solar panels.
  • Another participant questions the complexity of the proposed setup and suggests using mirrors instead, arguing that mirrors would simplify the design by requiring only the mirrors to move.
  • Some participants discuss the efficiency of solar panels with respect to different colors of light, noting that each color has corresponding panels that may perform better than a single panel designed for white light.
  • There is mention of the challenges in focusing light from multiple angles and the potential for using active cooling methods to manage heat in the proposed design.
  • One participant references the theoretical efficiency limits of photovoltaic cells and suggests that the proposed method could allow for testing different cells for different parts of the spectrum.
  • Another participant raises concerns about the practicality of using a prism for spectral separation, suggesting that it may not work effectively without collimated radiation.
  • There is a mention of existing technologies, such as triple-junction cells, that achieve high efficiencies without the need for spectral splitting.
  • A later reply introduces the Rainbow Concentrator, which claims to achieve similar goals with fewer components and materials, highlighting ongoing research in the field.
Participants express a range of views on the proposed design, with some supporting the idea while others offer alternative approaches or raise concerns about its feasibility. No consensus is reached on the best method for optimizing solar collection.
Participants note limitations regarding the efficiency of current solar panels and the challenges of focusing light effectively. There are also discussions about the implications of using different technologies and the potential for wildlife safety in solar collection designs.
RandomRed
Hello, looking for help designing building/testing and implementing an idea,
I have been thinking about using cheap flat panel magnifying lenses on a hinge and pivot, that track the sun, and then having a fiber optic at the focal point, and then having multiple fiber optics terminate at the same location, and have them hit a prism, splitting into the spectrum.
After the light is split into its component colors, I would like to test different panels for each color. Once panels are found for each spectra, an ideal panel could be grown.
ps. a side benefit would be that the heat would be concentrated to a small area for thermionic cells or solar hot water
roughed out a sketch in gimp
Science news on Phys.org
The magnifying glasses each have a fiber optic, and can be spread out, then all fiber optics come together,
its like having a few very efficient solar panels rather then a mess of weak ones.
each color of light has a corresponding solar panel, divide and conquer...
like a solar panel for UV would not be very good at collecting red.
I was thinking if there actively cooled and super efficient, you can use a single solar panel(expensive) and a large amount of plastic magnifying glasses and fiber optics(cheap)
to net at a higher efficiency and lower cost.
Do they actually make solar panels for each colour of light? Are they more effective than one for white light? (I don't know, it's a genuine question.)
Again, your magnifier / fibre optic setup is over complicated. You could use the mirrors to focus the light on a prism much simpler.
all solar panels have an absorption band, and no one panel absorbs 100% of the spectrum, there are many organisms that make use of a narrow band of light with VERY high efficiencies.
some panels are better with colors, in order to lower cost, and use of toxins, a very high efficiency small panel just makes more sense then a large volume of inefficient ones.also, about the fiber optics, its hard to get the light focused on a single target with light coming in from multiple angles, with this set-up you can always add another collector as long as the target is not overheating.(via active cooling with thermionic cooling or diamond semiconductors that can take a high volume of heat and conduct away the heat)
another plus is that local flying creatures are not spontaneously combusted...
Don't confuse organisms with technology. Not the same thing. At best out panels are currently 30% efficient.
Multiple angles? There's only the one sun last time I checked.
Did you look at the array in the picture I showed? 360 degree coverage.
Is that currently a problem?
So the theoretical limit to a photo cells efficiency is 86%, but by absorbing the waste heat you can go beyond that...
here is the source article http://en.wikipedia.org/wiki/Multijunction_photovoltaic_cell
my idea is to simplify the cell by feeding different cells different parts of the rainbow:)
Unfortunately, a prism generally only works under collimated radiation. Otherwise each color will not be properly separated.
Therefore, I recommend you remove the prism. You can buy triple-junction cells (e.g. from Azur Space, or Cyrium) with efficiencies above 40% under concentrated radiation. A 1cm*1cm square cell is about $10. These cells essentially use the full solar spectrum, but do not require spectral splitting.
You could also consider removing the fibre optic. Without the prism, there really is no use for it, other than the cell could remain fixed. But I think it would be easier just to build everything into a module, and then track the module.
Hope this helps.
the idea was to use small, high temperature single color cells, so you can use mostly plastic dishes/mirrors+ fiber optics, and focus all of the light on a small area, without flambeing any avian/insect wildlife... and then using the waste heat from the cell...
The Rainbow Concentrator by Sol Solution (www.sol-solution.net) does all this with one lens. It splits and concentrates the spectrum by taking advantage of chromatic aberration that you get on the outer part of a magnifying glass. This uses fewer parts and material compared to presented idea. It is cheap to build and can easily track the sun. I believe the reason you don’t already see it is that there is currently not a company producing the lateral single junction cells although ASU is currently working on it (http://nanophotonics.asu.edu/paper/Caselli_OE2011.pdf).
  • · Replies 152 ·
12K
13K
26K
