Ideal gas-thermodynamics, thermal equilibrium
The discussion revolves around a thermodynamics problem involving two ideal gases separated by a partition, focusing on their thermal equilibrium and energy changes. Participants are tasked with finding the final temperature and changes in specific thermodynamic quantities.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of the final temperature and total energy change for the system. There are attempts to derive expressions for changes in quantities H and A, with some participants questioning the implications of constant volume on these calculations. Others raise concerns about the path dependency of heat and work in thermodynamic processes.
Some participants have successfully solved parts of the problem, particularly the final temperature and some aspects of the energy changes. However, there remains uncertainty regarding the integration of certain expressions and the implications of path dependency. Guidance has been offered on how to approach the integration and the relationships between the variables involved.
Participants note that the volumes of the gases are constant, which influences the calculations. There is also mention of differing constants for the gases involved, which complicates the integration and final expressions for the quantities being evaluated.
oxman
Two ideal gases are separated by a partition which does not allow molecules to pass from one volume to the other. Gas 1 has: N1, V1, T1, Cv1 for the number of molecules, volume it occupies, temperature in kelvin, and specific heat per molecule at constant volume respectively. Gas 2 has: N2, V2, T2, Cv2. The two gases are in thermal contact and reach a final temperature
a) find the final temperature and the total change in energy of the combined system. Check your answer for the final temperature when N1=N2, V1=V2. Cv1=Cv2
b)Evaluate the total change ina quantity H whose differential change is dH=dU+Vdp for each component and for the entire system
c)evaluate the total change in a quantity A whose differential change is dA=(dU+pdV)/T for each component and for the entire system
U=NVCvdT
I already solved for the final temperature for part a, and when evaluated at equal N and V i got Tf=(T2+T1)/2
i am having trouble finding b and c
Note that the volume of each component as well as the entire system is constant. That means ## \frac p T = k = const ##. Use this to express both differential quantities via ## dT ##, then integrate, using the results of a) for the limits.
thanks voko, ur the man, i solved a and b since I've posted this however, i have yet to solve c, one of the TAs told me that the value "pdV" goes to 0 in the expression dA=(dU+pdV)/T however from here i am lost. i know that dQ=dU+dW and if pdV= 0 than dQ=dU, and i know that dQ=CvdT...but he said something about how this is path dependent and i need to prove that, any help?
Since ##U = cT##, where ##c## is some constant, ##dU = c dT##. ## p dV ## is indeed zero because the volume does not change. So all you have is ## dA = \frac {dU} T = \frac {c dT} T ##. I am sure you can integrate that.
thanks again voko for being the man, i did do that and i got, A=Cvln(Tf/T1) however my TA said that regardless since heat and work are path dependent i need to prove that dU=cdT since that is only applicable at certain times he said...
In #1, you gave the full expression for U. Differentiate it, paying attention to the conditions of the problem.
well in step (a) i got, Tf=(N1Cv1T1+T2Cv2N2)/(N1Cv1+N2Cv2), and for dU1=N1Cv1(Tf-T1) dU2=N2Cv2(Tf-T2)
dU=N1Cv1(Tf-T1)+N2Cv2(Tf-T2)
From here i can see there is no volume dependence, but I am not quite sure
Even if there were a volume dependence, it would not matter: all volumes are constant in this problem.
gotcha, thanks
If i wanted to solve dA=dU/T is there a way to do it without using CvdT=dQ
could i perhaps do:
dA1=dU1/T=N1Cv1dT/T then take the integral from T1 to Tf, and then do the same for dA2 and then add the two together?
That's exactly how you should solve this. All that alphabetical soup before dT/T is the constant c I mentioned earlier.
oh ok thanks a lot,
essentially i will get A=A1+A2
= c1(ln(Tf/T1)+c2ln(Tf/T2) where Tf=(c1T1+c2T2)/(c1+c2)
seems ugly, but there's got to be some way in which i can clean it up
i can't say c1=c2=c can i? because N1 doesn't equal N2
That is right, they are different. All of the gas constants in this problem seem to be different.
Ok,
so final answer i should get
A=c1ln((c1T1+c2T2)/(c1+c2)-T1)+c2ln((c1T1+c2T2)/(c1+c2)-T2)
i don't see a way to break this up further or clean it up other than writing it as ln(Tf/T)
thanks again for being so helpful, you truly are the man
You are welcome.
Your TA couldn't have meant that. He must know that for an ideal gas, dU is always equal to CvdT.
thats what i thought, I think he might have not realized that it said ideal gases in the problem
  • · Replies 33 ·
