Identifying Types of Converging Series
  • Thread starter Thread starter DameLight
    Converging Series
9 replies · 2K views
DameLight
Hello, I'm looking for some help with this problem for my Calculus 2 class. Since it's a summer class my professor wasn't able to explain everything fully so if you can help me that would be great : )
1. Homework Statement
Select the FIRST correct reason why the given series converges.
A. Convergent geometric series
B. Convergent p series
C. Comparison (or Limit Comparison) with a geometric or p series
D. Alternating Series Test
E. None of the above
1. Σn=1∞ 6(4)n/72n
2. Σn=1∞ sin2(6n)/n2
3. Σn=1∞ cos(nπ)/ln(2n)
4. Σn=1∞ (−1)n/(6n+5)
5. Σn=1∞ (n+1)(24)n/52n
6. Σn=1∞ (−1)n * √(n)/(n+9)
Geometric Series:
Σn=1∞ arn-1 will converge if -1 < r < 1
P Series:
Σn=1∞ 1/np converges if p > 1
Alternating Series Test:
1) bn+1 </= bn for all n and
2) limn->∞ bn = 0
1. A
2. B
3. E
4. D
5. C
6. D
1. Σn=1∞ 6(4)n/72n
Geometric Series:
P Series:
2) limn->∞ bn = 0
1. A
2. B
3. E
4. D
5. C
6. D
I get (in order 1-6) A, C, D, D, E, D.
My professor told me that I got numbers 2 and 3 correct
I disagree. Here are the details.
1. ##\sum 6 \;4^n/7^{2n} = 6 \sum (4/49)^n##, so geometric (A).
2. In ##\sum \sin^2 (6n) /n^2## the terms are (i) not geometric; (ii) not alternating; (iii) not in the simple form ##1/n^p##. However, ##0 \leq \sin^2(6n)/n^2 \leq 1/n^2##, so a comparison with the series ##1/n^2## works (C).
3. ##\sum \cos(n \pi)/ \ln(n) ## is an alternating series, since ##\cos(n \pi) = (-1)^n##. So, D.
4. ##\sum (-1)^n / (6n+5)## is alternating, so D.
5. ##\sum (n+1) \; 24^n / 5^{2n} = \sum (n+1) r^n, \;\; r = 24/25##. Here, A,B,C,D do not apply, and that leaves E.
6. ##\sum (-1)^n \sqrt{n}/(n+9)## (or ## \sum (-1)^n \sqrt{ n/(n+9)}##---can't tell which you mean) is alternating in either interpretation, so D.
The correct answer ended up being:
1. A
2. C
3. D
4. D
5. C
6. D
Thank you for your help : )
1. A
2. C
3. D
4. D
5. C
6. D
How do you get 5 C? Did you read my detailed explanation?
Why wouldn't the comparison test apply in ##5##? You can do ##n+1\leq \alpha^n## for some small enough ##\alpha>1##.
OK. That would be an answer to my question (why?) that the OP did not answer. For all I know the OP may have used false reasoning.
I don't want to assume, but that sounded a bit rude.
Still, your explanations are helpful.
I am assuming that going off of your explanation for 5 that we can compare that to a geometric function ∑n=0∞ anrn and since the absolute value of r is less than 1 we can go ahead and reason that the limit would be equivalent to a/(1-r)
No: a geometric series would be ##\sum r^n## (or ##\sum c r^n = c \sum r^n## for constant ##c##), but ##\sum a_n r^n## is NOT a geometric series if ##a_n## varies with ##n##. However, if ##a_n \to c = \text{constant} ## as ##n \to \infty##, then comparison with the series ##\sum c r^n## can be made to work without too much effort (although some extra effort is needed), However, in your case you have ##a_n = n+1 \to +\infty## as ##n \to \infty##, so that type of argument does not work automatically. If you thought it did, that is what what I would call "false reasoning".
However, as 'micromass' has pointed out, if you choose a small enough ##\epsilon > 0## so that ##(1+\epsilon) r < 1##, then for some finite ##N> 0## we have ##n+1 \leq (1+\epsilon)^n## for all ##n \geq N##, so for ##n \geq N## we have ##0 \leq (n+1) r^n \leq [(1+\epsilon) r]^n## and we can compare with the geometric series ##\sum [(1+\epsilon) r]^n##. Note, however, that some such argument as this must be acknowledged and recognized in order for C to be a valid and well-founded answer. Without this realization, just saying it would, again, be false reasoning.
