Identities for solving log questions
  • Thread starter Thread starter Saitama
    identities Log
96 replies · 15K views · last reply
Saitama
I was wondering if there could be more identities than i have read. I was doing questions on log and found many questions in this form:-
(loga b)2
(loga b)(loga c)
This is not my homework but i require these identities to solve the questions.
Please someone tell me how to solve these type of questions.
Thanks.
I don't believe there are any identities for these quantities.
True! :smile:
Pranav-Arora said:
I already checked them out before.
But I am having questions of this type, how would i solve them?
Do you have a specific question?
Well since the question isn't "use a log identity to simplify (logab)2 then they aren't exactly of this type now are they.
Ok, so no identities of this type exist...
But is it possible to simplify them?
Only if you know the numbers, then you can use a calculator. :wink:
The questions which i have to solve include variable so i can't use a calculator...:(
If you give us the question we'll be better equipped to help you.
Here's a question:-
Fraction: numerator (log_e x)^2 - 3log_e x + 3, denominator log_e x - 1, with the whole fraction shown as less than 1.
Now how would i solve (loge x)2
Pranav-Arora said:
Here's a question:-
Inequality: fraction with numerator (log_e x)^2 - 3log_e x + 3 over denominator log_e x - 1, less than 1.
Substitute y=loge(x) and solve for y.
When you're done (if you find a solution), back substitute x = ey.
Wow! Why i didnt just used my head?
It worked...
One more question, this time in the form (loga b)(loga c):-
Inequality (log base 4 of (x + 1)/(x + 2)) times (log base 4 of (x + 3)) < 0, written as a product of two logarithm terms.
Pranav-Arora said:
Edited! :-p
This is of the form:
a x b < 0​
The solution is:
a < 0 and b > 0​
or
a > 0 and b < 0​
Solve from there! :smile:
May i know why is
a < 0 and b > 0
or
a > 0 and b < 0
Pranav-Arora said:
May i know why is
a < 0 and b > 0
or
a > 0 and b < 0
If you multiply two positive numbers, the result is positive.
If you multiply two negative numbers, the result is positive.
If one of the two numbers is zero, the result is zero.
So one number must be positive and the other must be negative.
Thanks, it worked...
I am having loads of doubts and questions in log. Can i post them here one by one?
Sure. :)
That way it'll bump my attention.
Note that if I'm not available, you'll get a quicker response if you create a new thread.
Up to you though.
Thanks..:)
So my next question:-
Tinypic logo with the message 'This image or video has been moved or deleted'.
I solved it but i got stuck at:-
Fraction: numerator 2 times log base 5 of (x^2 - 4x + 11)/(x^2 - 4x - 11), denominator the square root of (2 - 5x - 3x^2).
Pranav-Arora said:
Thanks..:)
Tinypic placeholder graphic reading "THIS IMAGE OR VIDEO HAS BEEN MOVED OR DELETED" with the Tinypic logo above it.
Expression: 2 times log base 5 of ((x^2 - 4x + 11)/(x^2 - 4x - 11)), all divided by the square root of (2 - 5x - 3x^2).
How about multiplying left and right with the square root?
Note that a square root is always greater than or equal to zero.
Furthermore the base powers of the logs are different. That would make the equation a bit harder.
Are they different?
Because you applied the log-identities as if they are the same.
EDIT: Apparently you extracted the power of 2 inconsistently, because it should cancel.
Sorry its log11 (x2-4x-11)3
(I am solving the numerator part)
I changed the base log11 to log5.
It came out to be like this:-
log5 (x2-4x-11)
log5 11
log5 11 is around 1.5.
Then i got the numerator:-
- 3log5 (x2-4x-11) + 2log5 (x2-4x+11)
1.5
then reduced three to 2 since 1.5 *2 = 3
and then took 2 outside...
and i got the result where i am now stuck.
Pranav-Arora said:
@I like Serena:- Didn't you see my reply?
No, I didn't see your reply.
This time round I did not get a notification from either of your last 2 replies.
I don't know why, although I saw other threads mentioning that apparently the PF notification mechanism does not always work.
It's by coincidence that I happened to see in the forum overview that you posted new replies.
log5 (x2-4x-11)
log5 11
1.5
Let's not make approximations until we have to.
You'll get the wrong answer because of it.
If you work it out you should find:
[tex]2 \log_5 \frac {x^2-4x+11} {(x^2-4x-11)^\frac 3 {2 \log_5 11}} \ge 0[/tex]
This means:
[tex]x^2-4x+11 \ge (x^2-4x-11)^\frac 3 {2 \log_5 11}[/tex]
You should see that the power on the right hand side is slightly bigger than the one on the left hand side, meaning the inequality won't hold for large x.
Picking a large x and substituting it in your expression should show that the original inequality does not hold either.
[tex]2 \log_5 \frac {x^2-4x+11} {(x^2-4x-11)^\frac 3 {2 \log_5 11}} > 0[/tex]
This means:
Thanks it worked! You are really great!
My next question:-
[tex]\frac{\log_2 (x+10}{x-1} > 0[/tex]
(Sorry for the late reply..:(
I had been away for a few days)
My next question:-
[tex]\frac{\log_2 (x+10)}{x-1} > 0[/tex]
Uhh? What is your problem?
You'd have to consider the 2 cases where x > 1 and where x < 1 separately, but from there it should be straight forward? :rolleyes:
There's a closed bracket after 10.
And why i need to take these two cases?
If you multiply left and right by the denominator, the inequality will swap around if the denominator is negative.
(Note that this also plays a role in your first question! :wink:)
