Identities for solving log questions
96 replies · 15K views · last reply
I like Serena said:
If you multiply left and right by the denominator, the inequality will swap around if the denominator is negative.
(Note that this also plays a role in your first question! :wink:)
I did as you said.
I first took x>1 and tried to solve it.
I got:-
[tex]\log_2 (x+10) * (x-1) > 0[/tex]
So what's the next step...
Pranav-Arora said:
I did as you said.
I got:-
Hmm, what you should have is:
[tex]\log_2 (x+10) > 0[/tex]
And from there you get:
x+10 > 20
So:
x > -9
Since we restricted ourselves in this case to x > 1, that just leaves:
x > 1
Now we need to combine this result to what happens if x < 1 ...
lol...I didnt canceled (x-1) while multiplying both the sides with (x-1)...
I solved it but i am getting the answer to be (1,infinity) but when i checked the answer key it is (-1,0) U (1,infinity)...:(
I solved it four times but then too got the same answer...
Please help...
Please help...
What's the solution if x < 1?
Note that multiplying by (x-1) in this case inverts the inequality.
I am very sorry for my foolishness...:(
It wasn't "10", it was "1" but the method you gave worked successfully for my question...
Thank you very much!
I wanted to know that what is x when 2x > 0.
I solved it using the reverse of anti-log method and i got x > log2 0.
So what should i do next?
Think about the shape and details of any exponential graph.
Sorry Mentallic, i don't know about exponential graphs..:(
You still don't say what the question is, but I will guess that it is to find x so that the inequality is satisfied.
The product of two numbers is negative if and only if the two numbers are of opposite sign. So your problem reduces to
Case I:
[tex]log_4\left(\frac{x+ 1}{x+2}\right)< 0[/tex]
and
[tex]log_4\left(x+ 3)> 0[/tex]
or
Case II
[tex]log_4\left(\frac{x+ 1}{x+2}\right)> 0[/tex]
and
[tex]log_4\left(x+ 3)< 0[/tex]
You're solving logarithmic equations but you don't know what an exponential graph looks like? The latter should definitely come first in your studies...
Anyway, think about what the value of 2x is for large positive x, small positive x, small negative x and large negative x.
Uhm, I'm not sure what you're asking here, so here's from the top of my head.
2x > 0
This is true for any x.
x > log2 0
Yes this is equivalent (sort of), and since log2 0 = -∞, this means this holds for any x.
2x > 0
x > log2 0
Thanks! When i used log2 0= -infinity , my answer matched the answer in the answer key.
But when i was solving a problem i got 2x>-infinity. I applied the same process and got x > log2 -infinity. But log of negative number is not possible, so what should i do next?
There's no need to take a log in this case.
What you need to know is that 2x > 0 is always true for any x.
Sorry! But i didn't get you...
I like Serena said:
Do you get me now? :confused:
No i didnt get you! I am asking how to solve for x when 2x>-infinity...
Hmm, I'm trying to explain there's nothing to solve.
The solution set is the set of all real numbers.
How much do you know about exponentiation?
I take it you know that 21 = 2 and 22 = 4.
Do you also know that 2-1 = 1/2 and 2-2 = 1/4?
Here's a graph of an exponentiation function (actually ex):
Graph of y = e^x on a grid with x from -5 to 5, a blue curve rising from near zero on the left to steep growth on the right, labelled points (0,1) and (1,e).
Note that the graph is entirely above the x axis.
So 2x > 0 for any x.
And by implication 2x > - infinity for any x.
Graph of the exponential curve y = e^x on a grid, passing through the labeled points (0,1) and (1,e), rising steeply to the right and approaching zero on the left.
Thanks! I got it! So that means x is an element of all real numbers...
I am again getting a problem in this question:-
Tinypie logo with the message: This image or video has been moved or deleted
I solved it as you said I like Serena but i got stuck:-
[tex]x^2-4x+11 \ge (x^2-4x-11)^\frac 3 {2 \log_5 11}[/tex]
I am not able to figure out what should i do next? :confused:
Tinypie logo above the text "THIS IMAGE OR VIDEO HAS BEEN MOVED OR DELETED".
Mathematically speaking there's not much else you can do.
You can't solve this algebraically, but only numerically.
For values of x close to zero, the inequality holds.
For large positive x (starting around 20) or negative x (starting around -20), the inequality will not hold.
You can only find an approximation of these values.
When i checked out the answer key, i found the answer to be (-2,2- [tex]\sqrt{15}[/tex] )...
Would you please tell me how can i get this answer?
I don't understand why square root of 15 doesn't come in line with 2 :confused:
Here you can view the results of the equation:
http://www.wolframalpha.com/input/?i=%28log_5%28%28x^2-4x%2B11%29^2%29+-+log_11%28+%28x^2-4x-11%29^3%29%29+%2F+sqrt%282-5x-3x^2%29%3D0
So the approximate boundaries for x are -24 and +20.
This does not match the solution you just gave.
I already thought this problem was more complex than seemed likely seeing the difficulty level of the other problems you gave.
Is there perhaps a typo in your problem?
To get sqrt 15 in line, use either [ itex ] instead of [ tex ], or use the sqrt symbol √ (without tex).
Is there perhaps a typo in your problem?To get sqrt 15 in line, use either [ itex ] instead of [ tex ], or use the sqrt symbol √ (without tex).
Yes there is a typo. Its log11 (x2-4x-11)3.
But i already mentioned it before.
Yes, I already accounted for that.
And I just edited my previous post so you can simply click on the WolframAlpha link.
So what's the solution? :confused:
Looking only at the difference in log functions, this would be the set [ -20.9021, +24.9021 ].
However, we neglected to look at the square root denominator, because to have a proper solution, the expression within the square root must be greater than zero.
So we still need to solve:
2-5x-3x2 > 0
Do you know the solution to that one?
I think the answer shouldn't be -2,2-[itex]\sqrt{15}[/itex] because when i checked the answer key, a hint is given in the form of a big paragraph. In that, it is written "The trinomial 2-5x-x2 >0 for all x [itex]\in[/itex] (-2,3) and the denominator is only meaningful only for these values." But in the question it is given 2-5x-3x2. So now we are sure that the answer isn't -2, 2-[itex]\sqrt{15}[/itex].
And i can solve 2-5x-3x2>0 but would you please tell me how you got -20.9021, +24.9021. :confused:
Would you please also tell me what's the difference between these two statements (loga b)2 and loga2 b.
@I like Serena:-Also, just wanted to ask you that are you having this book "Problems in Mathematics with Hints and Solutions" by "V Govorov, P Dybov, N Miroshin & S Smirnova" and edited by "Prof. A.I. Prilepko" because i am asking these questions from this book?
Since we can't solve it algebraically, we need an approximation.
You can see it here:
http://www.wolframalpha.com/input/?i=%28log_5%28%28x^2-4x%2B11%29^2%29+-+log_11%28+%28x^2-4x-11%29^3%29%29%3D0
I have let Wolfram Alpha do the approximation for me.
Btw, there is yet another complication, which I missed before.
Since we have [itex]log_{11}( (x^2-4x-11)^3)[/itex] we have the additional constraint that [itex]x^2-4x-11 > 0[/itex] , because you can't take a log function from a negative number.
You'll have to solve that one as well.
No difference, the second form is a short hand notation of the first.
Sorry, but no, I don't have this book.
I don't have any books that explain your material. :biggrin:
You can only take the log of a positive number, so you must have: x2-4x-11 > 0 . For what values of x is that true?
Similarly, you can only take the square root of a non-negative number. Also, the square root is in the denominator, so you must also have: 2-5x-3x2>0 . For what values of x is this true?
It looks to me like the answer key is correct !
Look at this from WolframAlpha. (Give it extra computing time.)
:confused: :confused: :confused:
Ok i am writing everything what is given in the answer key:-
"Since the denominator of the fraction is always positive, the numerator must be [itex]\ge[/itex] 0 for the inequality to be satisfied. The trinomial 2-5x-x2 > 0 for all x [itex]\in[/itex] (-2,3), and the denominator is meaningful only for these values. The trinomial x2-4x+11 = (x-2)3 + 7 [itex]\ge[/itex] 7 for any x [itex]\in[/itex] R, and in that case log5 (x2-4x+11)2 > 0. The trinomial x2-4x-11 assumes nonnegative values for x [itex]\in[/itex] (-[itex]\infty[/itex], 2-[itex]\sqrt{15}[/itex]) [itex]\cup[/itex] (2+[itex]\sqrt{15}[/itex], +[itex]\infty[/itex]), and only for these values log11 (x2-4x-11)3 is meaningful. Thus, for left-hand side of the inequality to have sense, it is necessary that both inequalities be satisfied, i.e. that x [itex]\in[/itex] (-2, 2-[itex]\sqrt{15}[/itex]). On that interval f(x) = log11 (x2-4x-11) < 0. Indeed, f(-2) = log11 13 = 0, f(2-[itex]\sqrt{15}[/itex]) = log11 0 = -[itex]\infty[/itex]. The trinomial x2-4x-11 attains its minimum value for x=2. When varies to the left of x=2, the values of the trinomial increase continuously, for x=2-[itex]\sqrt{15}[/itex] its value is equal to zero, for x = +2 it is equal to 1; thus f(x) increase monotonically when x varies from 2-[itex]\sqrt{15}[/itex] to -2, remaining negative all the time. Consequently, on the left hand side of the inequality the numerator of the fraction is positive for x [itex]\in[/itex] (-2, 2-[itex]\sqrt{15}[/itex]) and the inequality is valid for these values."
Would someone please explain this to me? :confused:
What is it that you do not understand?
I would have to guess at what to explain.
Can you perhaps show what you do understand?
Let's break the solution down.
I'll start with the first sentence.
In an equality like:
a / b > 0
there are 2 ways to satisfy the inequality.
Either a and b both have to be positive, or a and b both have to be negative.
Since the denominator (b) is a square root, we already know that b >= 0.
All clear so far? :wink:
