Life on a Cubical Earth: Imagining Gravity and Everyday Challenges
The discussion centers on the hypothetical scenario of a cubical Earth where gravity acts uniformly across each surface. Participants argue that gravity would not allow people to feel upright on each surface, as they would instead experience gravitational pull akin to standing on steep mountains. The conversation highlights the unrealistic nature of the scenario, emphasizing that the laws of physics, particularly Newton's law of gravity, dictate that gravitational forces would not be perpendicular to the surfaces. Ultimately, the consensus is that such a situation is purely fictional and cannot be reconciled with established physics.
  • Understanding of Newton's law of gravity
  • Familiarity with gravitational force calculations
  • Basic knowledge of physics concepts related to gravity and force vectors
  • Awareness of hypothetical scenarios in physics
  • Explore gravitational force calculations using Newton's law of gravity
  • Research the implications of artificial gravity in theoretical physics
  • Study the effects of gravity on different planetary shapes and structures
  • Investigate the concept of gravitational fields and their behavior in non-standard geometries
This discussion is beneficial for physicists, science fiction writers, and educators interested in exploring theoretical physics and the implications of gravity in unconventional scenarios.
AdityaDev
I was thinking about a situation where we lived in a cubical earth! (Gravity is such that people at each surface will still feel that they are standing upright). I came up with some interesting situations like when a ship crosses an edge or throwing a ball from the edge of surface... What would life be like, in such a scenario?
The Bizarro World ...
http://en.wikipedia.org/wiki/Bizarro_World
Is that true? I don't think it is.
No, gravity doesn't work that way. People on each surface would feel that they are climbing one of 8 giant mountains. They would not think that the surface is horizontal.
Why can't gravity act perpendicular to the surface? Like field lines are uniform along positive x direction passing through the y-z plane?
My interpretation of the OP's post is that he is declaring that gravity would be arranged that way - not that it would naturally be that way.
Thing is, as soon as he does that, he has to come up with the answer to his own question - because it's artificially constructed. To what resolution does the gravity remain normal to a surface? If you are standing one hundred yards from the edge, do you feel gravity normal to the ground i.e. no effect from the other surface? What about one foot from the edge? What if you straddle the edge? Would each leg be pulled in unique direction? Which way would your head be pulled?
Are you asking why physics works the way it does?
If you stand on the side of a steep hill, which way would gravity pull you? Would you expect to stand perpendicular to the side of the hill?
The situation is unreal. That's what I wanted to mean. It's hypothetical. Well for simplicity the field lines at one surface do not affect the other. If he is in surface 1, he will feel the gravitational pull of surface 1.
If he puts one leg on one surface and the other on an adjacent surface?? I don't know what's going to happen.
No no. If a person stands on a mountain of inclination theta (mountain on surface '1') then he will feel mgsin(theta) along surface and mgcos(theta) along the normal to mountain surface.
Right. So it's up to you to make up your own scenario. Decide how your fictional artificial gravity generators operate, where they are placed (presumably underground), and how their fields attentuate. Then your occupants will be able to tell where "down" is.
If you actually calculate the gravitational force on the surface using Newton's law of gravity (you will need to do some integration here) , you will find that DaleSpam's response is accurate - unless you suspend the law of gravity, the gravitational field will not be generally perpendicular to the surface and walking to a corner will be like climbing a really high mountain.
If you do the calculations you will also find that the forces on the corners are so great that even solid rock cannot resist them so the corners will be pulled down towards the center. This is, of course, why the Earth and all other planet-sized bodies are spherical.
AdityaDev said:
The situation is unreal. That's what I wanted to mean. It's hypothetical...I don't know what's going to happen.
Nor does anyone else, as your question is basically "What do the laws of physics say will happen in a situation in which the laws of physics don't apply?". That's not going to be a productive physics forums discussion so the thread is closed.
  • · Replies 25 ·
  • · Replies 16 ·
  • · Replies 33 ·
