If f''(a) exists then f''(a) = ....
  • Thread starter Thread starter Euklidian-Space
The discussion revolves around proving that if the second derivative f''(a) exists for a differentiable function f on an open interval I, then it can be expressed as the limit of a specific difference quotient: f''(a) = lim(h→0) [f(a + h) - 2f(a) + f(a - h)] / h². Participants explore various approaches, including using the limit definition of the derivative and Taylor's theorem, to manipulate the expressions and derive the desired limit. The conversation highlights the challenges of combining limits and the application of L'Hôpital's rule to resolve indeterminate forms. Ultimately, the proof hinges on demonstrating continuity and the behavior of the function's derivatives as h approaches zero. This establishes the relationship between the second derivative and the limit expression provided.
Euklidian-Space
Let ##I \subset \mathbb{R}## be an open interval and let ##f:I \rightarrow \mathbb{R}## be differentiable on I. Show that if ##f''(a)## exists, then ##f''(a) = \lim_{h \rightarrow 0}\frac{f(a + h) - 2f(a) + f(a - h)}{h^2}##
I tried tackling this by using limit definition of the derivative for ##f''(a)##.
$$f''(a) = \lim_{h \rightarrow 0}\frac{f'(a + h) - f'(a)}{h}$$[/B]
and then maybe use limit definition again for the terms in the numerator above? maybe use L'hopitals's rule? Not sure
Can you then write down the definition in terms of limits of ## f'(a + h) ## and ## f'(a)## ?
Use Taylor's theorem: If f is twice differentiable at a then <br /> f(a + h) = f(a) + hf&#039;(a) + \frac12 h^2f&#039;&#039;(a) + \epsilon(h) where <br /> \lim_{h \to 0} \frac{\epsilon(h)}{h^2} = 0.
Using the limit definition of differentiation in the numerator and sone manipulation will give you the answer.
Ok so the limit def of diff for the following
$$f'(a) = \lim_{h \rightarrow 0} \frac{f(a + h) - f(a)}{h}$$
$$f'(a + h) = \lim_{h \rightarrow 0} \frac{f(a + 2h) - f(a + h)}{h}$$
The def of f'(a + h) I am not too sure about.
<br /> f&#039;(a + h) = \lim_{k \to 0} \frac{f(a + h + k) - f(a + h)}{k}.<br />
pasmith, How do you deal with that index of k when we are trying to simplify the numerator of
I don't; I would instead use the Taylor theorem approach I suggested in my earlier post.
No need to use taylor, just "fuse" limits, using your notation, it is clear that f'(a+h) = lim h->0 f(a+2h)-f(a+h) / h and the same for f'(a), and write all the limits as one, show me you attempt so far !
False: \lim_{h \to 0} \frac{f(a + 2h) - f(a + h)}h = \lim_{h \to 0} \frac{f(a) + 2hf&#039;(a) - f(a) - hf&#039;(a)}h = f&#039;(a).
What happens if you put these into your expression for ##\ f''(a)\ ?##
You get something pretty close to what you're looking for.
Since the limit exists, it is the same as each of its one-sided limits. So, isn't it true that ##\displaystyle \ f''(a) = \lim_{h\to 0}\frac{\,f'(a - h) - f'(a)\,}{-h}\ ?##
Not false, of course lim h-> 0 f'(a+h) = f'(a), f is continuous and free if corners, you haven't prooved or denied anything !
When i put those into my expression for f''(a) i get this...
$$\lim_{h\rightarrow 0} \frac{\lim_{h\rightarrow 0} \frac{f(a + 2h) - 2f(a + h) + f(a)}{h}}{h}$$
what on Earth am I suppose to do with that monster?
You are given that ##f## is differentiable on an open interval. That gives you the right to apply l'Hopital once if you can show it's a 0/0 form. THEN apply definitions of differentiability.
You really should be using two different variables for the limits.
$$\lim_{h_1\to 0} \frac{\lim_{h_2\to 0} \frac{[f(a + h_1 + h_2) - f(a + h_1)] - [f(a+h_2)-f(a)]}{h_2}}{h_1}.$$ The question you've run into now about how to combine the two limits into one is probably why pasmith suggested the other method using Taylor's theorem. I don't offhand see how to justify combining the limits.
it seems even with the taylor method you get into the same problem.
$$f(a + h) = f(a) + hf'(a) + \frac{1}{2} h^2f''(a) + \epsilon (h)$$
solve for f''(a) and get
$$f''(a) = \frac{2f(a + h) - 2f(a) - 2hf'(a) - 2\epsilon (h)}{h^2}$$
so i guess at this point you would take limit of both sides, but what do you do about the 2hf'(a) in the numerator?
How do you know Taylor's theorem is correct? Hint: You need the limit that the original post requires to be proved.
DEvens, would you use the limit definition for differentiation to prove this? If so how would you resolve the different limit variables?
Hint: Consider both f(a+h) and f(a-h).
I only need that \lim_{h \to 0} \frac{\epsilon(h)}{h^2} = \lim_{h \to 0} \frac{f(a + h) - f(a) - hf&#039;(a) - \frac12h^2f&#039;&#039;(a)}{h^2} \\<br /> = \lim_{h \to 0} \frac{f&#039;(a + h) - f&#039;(a) - hf&#039;&#039;(a)}{2h} = \frac{f&#039;&#039;(a) - f&#039;&#039;(a)}{2} = 0 using l'Hopital's Theorem and the definition of the second derivative. The OP's limit then follows. :smile:
(l'Hopital's Theorem would also work to establish the OP's limit directly, once one has proven that <br /> \lim_{h \to 0} \frac{f(x + h) - f(x - h)}{2h} = f&#039;(x).)
If you prefer not to use Taylor's theorem, follow Dick's suggestion and apply L'Hopital's rule to
$$\lim_{h \to 0} \frac{f(a+h)-2f(a)+f(a-h)}{h^2}.$$
ok when i apply l'hopital's i get the following
$$\lim_{h \rightarrow 0} \frac{f'(a+h) - f'(a - h)}{2h}$$
we differentiate the numerator and denominator with respect to the limit variable right? doesn't seem like it is giving us ##f''(a) = \lim_{h \to 0} \frac{f''(a + h) - f''(a)}{h}##
What can you do to the numerator so that it contains combinations that look like the numerator in the definition of a derivative?
Well I tried applying lhopitals again. But I get ##\lim_{n\to0} \frac{f"(a+h) - f"(a-h)}{2}##. Which seems to be a little closer, but not quite.
Well I tried applying lhopitals again. But I get ##\lim_{h \to 0} \frac{f"(a+h) - f"(a-h)}{2}##. Which seems to be a little closer, but not quite.
The derivative of f&#039;(a - h) with respect to h is -f&#039;&#039;(a - h), so you should have <br /> \lim_{h \to 0} \frac{f&#039;&#039;(a + h) + f&#039;&#039;(a - h)}{2}. Now if you knew that f'' was continuous at a you would be done, but you don't. Also, we are only assuming that f is twice differentiable at a, so it is entirely possible that f&#039;&#039;(a + h) does not exist for any h \neq 0. So l'Hopital's rule can only take you as far as <br /> \lim_{h \to 0} \frac{f&#039;(a + h) - f&#039;(a - h)}{2h}.
oh i think I see now
wait how do you get
wait how do you get
\lim_{h \to 0} \frac{f&#039;(a + h) - f&#039;(a) - hf&#039;&#039;(a)}{2h} = \frac12 \lim_{h \to 0} \frac{f&#039;(a + h) - f&#039;(a)}{h} - \frac{f&#039;&#039;(a)}{2} and by definition <br /> f&#039;&#039;(a) = \lim_{h \to 0} \frac{f&#039;(a + h) - f&#039;(a)}{h}.
  • · Replies 20 ·
