If it takes 17 seconds to blow up a balloon to 8 cm in diameter
The problem involves determining the time required to inflate a balloon from 8 cm to 24 cm in diameter, given that it takes 17 seconds to reach the initial size. It incorporates concepts of gas behavior, pressure, volume, and surface area in the context of balloon inflation.
  • Participants discuss the relationship between pressure and volume in gas laws, questioning how to account for pressure changes during inflation. There are attempts to calculate volume differences and relate them to time, while others suggest considering the proportionality of pressure to surface area.
The discussion is active, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the application of gas laws and the relationship between volume and pressure, but no consensus has been reached on the correct approach to take.
Participants are considering assumptions about the behavior of gases under pressure and whether to disregard certain factors in their calculations. There is an acknowledgment of the complexity introduced by pressure changes as the balloon inflates.
some_letters
If it takes 17 seconds to blow up a balloon to 8 cm in diameter, how much longer will it take to inflate the balloon to 24 cm in diameter? Assume that the pressure that the balloon exerts on the air inside is proportional to the surface area of the balloon, that you blow a constant number of molecules of air per unit time into the balloon regardless of the pressure, and that the balloon retains the same shape as it is being inflated.
V = 4/3 pi r^3
SA = 2pi r^2
I've found out how much volume each size contains, subtracted one from the other, then applied the rate to the volume and it is wrong
Did you account for the fact that gasses under higher pressure occupy a smaller volume when under pressure? That seems to be vital to the question.
How would I even account for that?
Well by from the gas law PV=nRT where P is pressure, V is volume, n is the number of mols gas involved(or for this question we can just say it is the number of molecules), R is the gas constant, and T is temperature. You will want to find a ratio between the number of molecules in the 8cm balloon and the 24cm balloon.
I have a feeling that it means for us to disregard that. Is that the only way to do the problem?
What I did was calculate the volume when the balloon had a 4 cm diameter, and calculate the cm^3/ second x.
x * (Vf - Vi) = how many seconds
Is there something fundamental I am forgetting?
Well that would be right if it weren't for the pressure thing.
Basically what you would do is
3r_1=r_2 because 12/4=3
V_1=4/3 \pi r_1^3V_2=4/3 \pi r_2^3=4/3 \pi (3r_1)^3
so you will get V_2=27V_1
then do the same for pressure, then try to express n_2~ in~terms ~of ~n_1
and remember that pressure is proportional to surface area so if balloon 2 has a surface area 5 time that of balloon 1 then it will exert 5 times the pressure.
  • · Replies 18 ·
22K
  • · Replies 17 ·
11K
