If it takes 17 seconds to blow up a balloon to 8 cm in diameter
To determine how long it takes to inflate a balloon to 24 cm in diameter, one must first calculate the volume of both the 8 cm and 24 cm balloons, noting that the volume increases significantly due to the cubic relationship of radius. The pressure exerted by the gas inside the balloon is proportional to its surface area, which complicates the inflation time as the pressure increases with size. The relationship between the number of air molecules and the balloon's volume must be considered, as higher pressure means gas occupies a smaller volume. The calculations involve using the gas law and understanding the ratios of volumes and pressures between the two balloon sizes. Ultimately, the problem requires careful consideration of both volume and pressure dynamics to arrive at the correct inflation time.
some_letters
If it takes 17 seconds to blow up a balloon to 8 cm in diameter, how much longer will it take to inflate the balloon to 24 cm in diameter? Assume that the pressure that the balloon exerts on the air inside is proportional to the surface area of the balloon, that you blow a constant number of molecules of air per unit time into the balloon regardless of the pressure, and that the balloon retains the same shape as it is being inflated.
V = 4/3 pi r^3
SA = 2pi r^2
I've found out how much volume each size contains, subtracted one from the other, then applied the rate to the volume and it is wrong
Did you account for the fact that gasses under higher pressure occupy a smaller volume when under pressure? That seems to be vital to the question.
How would I even account for that?
Well by from the gas law PV=nRT where P is pressure, V is volume, n is the number of mols gas involved(or for this question we can just say it is the number of molecules), R is the gas constant, and T is temperature. You will want to find a ratio between the number of molecules in the 8cm balloon and the 24cm balloon.
I have a feeling that it means for us to disregard that. Is that the only way to do the problem?
What I did was calculate the volume when the balloon had a 4 cm diameter, and calculate the cm^3/ second x.
x * (Vf - Vi) = how many seconds
Is there something fundamental I am forgetting?
Well that would be right if it weren't for the pressure thing.
Basically what you would do is
3r_1=r_2 because 12/4=3
V_1=4/3 \pi r_1^3V_2=4/3 \pi r_2^3=4/3 \pi (3r_1)^3
so you will get V_2=27V_1
then do the same for pressure, then try to express n_2~ in~terms ~of ~n_1
and remember that pressure is proportional to surface area so if balloon 2 has a surface area 5 time that of balloon 1 then it will exert 5 times the pressure.
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
