If statement & PopUp window in React
The discussion revolves around implementing a popup window in a React application that is triggered by selecting a radio button. Participants explore various methods to achieve this functionality, including the use of conditional statements and different popup libraries.
  • Homework-related
  • One participant inquires about the correct usage of an if statement in React to show a popup when a specific radio button is selected.
  • Another participant shares their updated code for implementing a popup and asks for styling suggestions.
  • There is a clarification that the component being discussed is a modal dialog rather than a traditional popup.
  • Participants discuss the need for a close button in the popup and the differences between popups and dialogs in Material UI.
  • One participant reports success in implementing a solution after receiving guidance on closing buttons.
  • Further questions arise regarding setting the height of a card to match the screen size across different resolutions.
  • There is a discussion about using specific height values in the TreeView component's styling.
  • A participant seeks advice on keeping an input field and button aligned on the same line when resizing the screen.
Participants express varying opinions on the best approach to implement popups and dialogs, and there is no consensus on the optimal method for styling or functionality. The discussion remains unresolved on some technical aspects, particularly regarding the integration of different UI components.
Some participants mention issues with TypeScript versus JavaScript in the context of using Material UI, indicating potential limitations in their current setup. There are also unresolved questions about specific styling practices and component behaviors.
mathmari
MHB
Hey! :smile:
I have a checkbox with radio button and I want that a popup message is shown if we have selected the second option. I tried to do that with if statement but it doesn't work. How do we write the if statement in React? Isn't it 'condition ? true : false' ? Do we not check if the value or the id is the one of the correct option?
And also how is the popup message defined?
The part for the radio buttons that I used is :
JavaScript:
<input type="radio" id="No" value="No" name="answer" /> No
<input
     type="radio"
     id="Yes"
     value="Yes"
     name="answer"
     style={{
              marginLeft: '55%'
Yes
I want that if we select the answer 'Yes' then a pop up message should appear.
As for the pop up I tried:
JavaScript:
<Popup trigger={<button> Trigger</button>} position="right center">
              <div>Popup content here !</div>
</Popup>
But this just makes visible or invisible respectively the part in <div>. How does a pop up window appear?
Technology news on Phys.org
I wrote now the following :
JavaScript:
      <Popup
         trigger={
            <label>
              <input
                  type="radio"
                  id="Yes"
                  value="Yes"
                  name="answer"
                  style={{
                      marginLeft: '55%'
               Yes
            </label>
        <div>
           <h3>Why</h3>
               <label>
                  <input type="radio" value="reason1" name="reason" />Reason1
                  <br></br>
                  <input type="radio" value="reason2" name="settings" /> Reason2
               </label>
       </div>
Now I get a popup of the form :
Could we style it do get a popup of the form :
pbuk said:
No, that's not a popular, it's a (modal) Dialog: https://mui.com/material-ui/react-dialog/
Different animal.
I have already tried the version of the link you sent but I get an error message that it must be typescript instead of javascript. 🤔
mathmari said:
JavaScript:
      <Popup
         trigger={
            <label>
              <input
                  type="radio"
                  id="Yes"
                  value="Yes"
                  name="answer"
                  style={{
                      marginLeft: '55%'
               Yes
            </label>
        <div>
           <h3>Why</h3>
               <label>
                  <br></br>
               </label>
       </div>
I used now the above code and I have add two buttons, one "Close" and one "OK", but I got stuck on how to make the "Close" Button to close that popup window. Could you help me with that? 🤔
What exactly is the message?
Have you noticed there are now 2 versions of the boilerplate scripts on the MUI documentation site - you switch between them with the buttons at the top left of the box: the image below shows Typescript select (by default). If you do not have a TS transpiler in your build chain you will need to select the JS version.
Ah ok! And then when we want to call it we define <FormDialog /> ? 🤔
Popup is not a Material UI component (there are two with subtle differences: Popover or Popper). Note that popups/popovers don't generally have buttons, they are intended to close when you click elsewhere. If there is more interaction the normal design idiom is a dialog.
If you are using reactjs-popup there is documentation on closing buttons here https://react-popup.elazizi.com/react-modal/, however note that Material UI is designed to be a complete UI framework and may not play nicely with 3rd party components.
It works with that! Thank you! :smile:
I have also an other question : I want to make the height of a card equal to the size of the screen, but this is not the same for each resolution. Is there a way to make it equal to the screen for each resolution? 🤔
Set the height to "100vh" (100% of the view height).
Ok!
Can we use this one also in the TreeView sx?
JavaScript:
<TreeView
       aria-label="file system navigator"
       sx={{ flexGrow: 1, height: 195, maxWidth: 350, overflowY: 'auto' }}
Because here we just have a number, not px or something like that.
mathmari said:
Ok!
JavaScript:
<TreeView
I've no idea - I don't use React MUI - but according to POLA (the principle of least astonishment, a fundamental rule of API design), I would guess that in the sx parameter strings are passed verbatim and numbers are appended with 'px'. I would try height: '100vh'.
Ok! I have also an other question. I have an input field for the Name the next to the input field a button, but I make the scrren smaller the button goes down. How can I make it that the input field and the button get smaller but stey on the same line?
So far my code for that is :
JavaScript:
                                           <label>
                                                <input
                                                    type="text"
                                                    name="name"
                                                    placeholder="Type your name"
                                                    style={{
                                                        width: '25vw',
                                                        height: '5vh',
                                                        marginTop: '15px',
                                                        float: 'left'
                                            </label>
                                            <button
                                                id="btn"
                                                style={{
                                                    width: '8vw',
                                                    height: '5vh',
                                                    borderWidth: '0',
                                                    fontWeight: 'bold',
                                                    float: 'right',
                                                    marginTop: '15px'
                                                OK
                                            </button>
<input> is a plain HTML element and setting styles like that won't work. You need to use the MUI TextField component https://mui.com/material-ui/react-text-field/
How can I connect the react with FastApi? For example we have this input field with the OK button, and we have the endpoint (POST Request) /name/
Now we have to save the input at the input field in the database with the endpoint /name/ or not?
So when we call the link .../name/ then at the input field we give a name and this one must be saved in the database? Is that correct? Is that the meaning to connect the endpoints with the frontend?
I have to write the code for the request inside the jsx code where I made the input field and so on , right? First I write :
JavaScript:
    const client = axios.create({
        baseURL: "https://giant-db-connection.onrender.com/server"
and then I have to save in a variable the input of the input field, or not?🤔
That all depends on what the particular API you are connecting to requires.
Absolutely not! The whole point of frameworks like React is the separation of concerns: in other words don't mix your business logic in with your presentation layer. You should do this using an event handler like in https://reactjs.org/docs/handling-events.html. That example uses the onClick event on a button, you will probably want to use the onChange event on an input (or onSubmit on a form for handling a number of changes).
So at the beginning we define:
JavaScript:
and then inside the code for the input field we need an onClick:
JavaScript:
                                                  <button
                                                        id="btn"
                                                        type="submit"
                                                        style={{
                                                            width: '98px',
                                                            height: '40px',
                                                            fontWeight: 'bold',
                                                            float: 'right'
                                                        onClick={activateButton}
                                                        OK
                                                    </button>
and then we have to define activateButton ? 🤔 I have seen the following example with GET :
JavaScript:
const TreeList = () => {
        baseURL: "https://abc.com/name"
    const [dataTree, setdataTree] = useState([]);
    // GET with Axios
    useEffect(() => {
        const fetchdataTree = async () => {
        let response = await client.get('');
        setdataTree(response.data);
        fetchdataTree();
    return (
        <div className="row ml-1">
            <div className="col">
                <div className="row mt-2 ">
                    <div className=" text-dark col">
                    {dataTree.length > 0 && <Tree data={dataTree[0].tree_structure[0].Nodes } />}
                    </div>
                </div>
            </div>
        </div>
So do I maybe have to use also at POST the useEffect() as follows?
JavaScript:
useEffect(() => {
        let response = await client.post('');
        fetchdataTree();
As for the POST request with Axios I did :
JavaScript:
const [server, setServer] = useState('');
    const handleSubmit = (e) => {
        e.preventDefault();
        axios
            .post(`https://giant-db-connection.onrender.com/server`, { server_url: server, polling_time: 0 })
            .then((res) => console.log(res))
            .catch((error) => console.error(error));
which works! Which is corresponding GET request? Just .get instead of .post? Or how is the GET request defined?
Well yes axios.get() will perform a GET request, but what the path and query parameters (if any) should be depends on the API. Also it would be better to use the client you have set up instead of writing the whole URL all the time something like
JavaScript:
        baseURL: "https://giant-db-connection.onrender.com",
        // If you don't set a timeout it will wait forever if something is wrong.
        timeout: 5000, // 5s.
    // Async/await syntax is nicer so declare the arrow function as async.
    const handleSubmit = async (e) => {
        e.preventDefault();
        try {
            const res = await client.post('/server', { server_url: server, polling_time: 0 });
            console.log(res);
        } catch (error) {
JavaScript:
        e.preventDefault();
        try {
            console.log(res);
        } catch (error) {
Ah ok! To call this POST request we go click on a button and with onClick we call then the above function, right?
What happens with a GET request? Then we don't click on a button, we just want that something is shown up, right? Do we just call then the function?
Is the GET request as follows when we want that just the Attributes are shown, as you see in the belox picture?
JavaScript:
const [parsed_tree, setParsedTree] = useState('');
    useEffect(() => {
        ParsedTree();
    const ParsedTree = () => {
        axios
            .get(`https://giant-db-connection.onrender.com/opc_ua_tree`)
            .then((res) => ((attributes = res.data.tree_structure.Nodes.Attributes), setParsedTree(attributes)))
Or in JSON format :
I have changed this and I think the way I get the attributes is now correct :
JavaScript:
    useEffect(() => {
        ParsedTree();
        axios
            .then(
                (res) => (console.log((attributes = res.data[0]['tree_structure'][0]['Nodes'][0]['Attributes'])), setParsedTree(attributes))
The point where I got stuck right now is how to display the attributes. Do we do that with .map ? 🤔
It’s not a good idea to fetch data directly in components - it’s that separation of concerns thing again. I would look at Redux, it’s designed to work well with React and it’s got a pretty good tutorial.
So is the way I do the get request completely wrong? Or just how I want to display it? 🤔
When the above code is correct do we use .map to display the data?
JavaScript:
{setParsedTree .map((x) => {
     <TreeItem nodeId="{x}" label={x} />;
No, it's probably fine (I haven't checked the detail but if it works then it works!).
But the problem comes when you want to display somewhere else e.g. the StartTime for the node with id "i=2257". If you keep the data inside a component's event handler you will have to fetch this from the server again, however if you store the query result as part of the state of a global store you can use it wherever you want - and if that state is implemented in a reactive store then everything stays updated automatically. Redux is one such store, and is the one most often used with React.
JavaScript:
That depends on the structure of your data and how the TreeItem component you are using works. I think you need to work that out for yourself, I can't design your whole app for you. (Well I can, but it wouldn't be cheap).
But you do have to write code that parses though: think about what you are trying to get the compiler to do with {setParsedTree .map((x) => {.
Or FOLLOW A TUTORIAL.
In React can we use a while loop?
I want to return a Tree so do I not have to check if there are other non-empty children to be printed? How is this defined in React? 🤔
React is just JavaScript (or TypeScript) so yes, you can use a while loop, although you might find that you use a forEach iterator more often. We usually add another extension to JavaScript, JSX, which means we can do something like this inside our render() method:
JavaScript:
  return (
    <div class="node">
      <h3>{node.title}</h3>
      // Check if there are any child nodes.
      if (node.children.length) {
        <ul>
          // Recursively print child nodes.
          node.children.forEach((childNode) => {
            <li><DisplayNode node={childNode} depth={depth + 1}/></li>
        </ul>
    </div>
See commented code above.
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 25 ·
